Question about Fender R) Pro Junior III Guitar Amplifier - Black
Pro Junior III Guitar Amplifier - Hello,When I turn it on there is loud buzzing noise that does not change with volume.Thanks
  • Fender Master
  • 5,603 Answers
There is likely one of three problems:
Blown rectifier in power supply.
Bad filter capacitor(s) in power supply.
Shorted power amp chip causing the riple on the power supply to reach the speaker.
Posted on Mar 14, 2011
Am getting a bad buzzing noise from my laney lc15
Bad connection? Loose fittings? I used to get a crackle from my amp when I turned the volume or balance knobs. A quick spray of WD 40 down the shaft after removing the knobs fixed it.
Mar 13, 2016 | Laney LC15-110 Guitar Combo Amplifier (15...
Fender Acoustisonic Jr. One day I played it at its highest volume, then turned it off. Came back to play it 20 min. later and it wouldn't make a sound. You can slightly hear the guitar buzzing when...
I would try using another speaker to see if you can get the sound back, this will help you narrow down the problem, you can also use the effect send to feed anothe amp to see if you get the sound OK.
It can be blown speaker or output stages,
Jul 08, 2011 | Fender Acoustasonic Junior Dsp Combo...
Fender acoustasonic junior crackling loudly and electronic buzz when touch volume knobs
noise problem with fender jr accoustatics is the poor aluminum sheet ground design that wraps around the body of the amp. it happens to me all the time because i kept on moving/carrying/dropping the amp every time we do church service. i am thinking of using an aluminum cable to wrap around outside the body.
Jul 07, 2011 | Fender Acoustasonic Junior Dsp Combo...
When I turn on the amp, I get a loud hum. plugging into the jack doesn't change anything. turning the dials doesn't change anything. when I turn off the amp it makes a loud crack.
i) Disconnect one lead of loudspeaker & insert an open-ended guitar cable into headphone socket.
ii) Put a dc voltmeter across open end jack then turn Frontman ON for a few seconds.
iii) The reading should be about 0volts - if the voltage is high (27v), then it is likely that the PA chip TDA1514A has blown.
iv) If,however, the voltage is correct in iii) , then reconnect speaker & put guitar cable into the POWER AMP IN socket & connect other end to guitar...Turn on briefly, if there is still hum then fault is in the output stages & will require chassis removal to solve.
Feb 23, 2011 | Fender FrontmanTrade 25r Combo Guitar...
I have a buzzing noise through my MG50dfx every time I use the foot switch and have changed to the over dive/distorted sound. Any help would be wonderful?
Has it always done this? If it's just a mild hissing sound, chances are it's normal. If it's a loud obnoxious buzz, is your gain cranked all the way up? If it is, turn it down about half way and see if it goes away. If not, take it in to a good guitar store for service/diagnosis.
Feb 22, 2011 | Marshall Mg50dfx 50-Watt Combo Guitar...
When I'm playing on my amp there is a strange noice coming out of my amp. At first I thought it was my guitar, but it is really my amp... does anyone know how to solve?
"A strange noise" does NOT give us much to go on...
Please note that relatively low volume digitizing noise often exists from teh digital effects processors... it should be well below the normal playing volume.
Aug 09, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
Aug 27, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
My spider III 15 watt buzzes whenever i have a cable plugged in.
MAKE sure you have it connected to a three wire circuit that has the ground. A lot of these style amps will buzz if they are left ungrounded.
Also search for sources of buzzing light light dimmers.
Further, power supply electrolytic filter caps are suspect.
Aug 23, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Nothing but loud buzzing coming over the amp when trying to play. Any suggestions?
If the buzz disappears when you unplug the cable from the amp. check your cable.
If the buzz disappears when you unplug the cable from the instrument, there's something thay may have come loose inside the instrument.
If you unplug the cable from the amp., and the buzz persists, you'll have to have a competent tech. check your amp.
Apr 14, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
I have just purchased a Yamaha EG012 and a Yamaha GA-15 Amplifier. I've followed the instructions adn plugged everything in, but when i turn on the amp and adjust the volumes there is just a buzzing noise...
You may have a switch with 2 settings somewhere on your amp - one for active and one for passive. try changing that.
If this doesn't work, make sure you got the guitar in the line input, change the lead for another incase it's faulty, turn the volume up on the guitar to activate the pickups, and rock-out when you find the problem and fix it.
Dec 30, 2008 | Yamaha Electric Guitar
Fender R) Pro Junior III Guitar Amplifier - Black Logo
190 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
