Question about Jenn-Air Grilling
Recently had grill igniters repaired....now when turned on....seems to be on half power....not real hot...is there air in the gas line? ( natural gas)
  • Frank Schultz
    Frank Schultz Mar 20, 2011
    When you say igniters, do you mean the electrodes that light the burners?
  • Jenn-Air Master
  • 43,501 Answers
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101 //
Posted on Apr 02, 2011
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Natural gas grill low flame
Did you change the reg , lpg burns at 14 inches wg nat gas burns at 4inches wg
Feb 16, 2013 | Char-Broil Commercial Stainless Steel...
The igniter connection does not have the white cover to the side burner so part of the igniter metal is exposed. When I look at other grills, there is a white couplilng type piece so the igniter wire
It'll be fine...A tiny explosion happens anyway when a grill is lit.. Its just a ceramic fitted piece... Its ok...you can still grill..;-) if you replace you'll have to replace the whole ignitor.Have fun grilling....
Nov 20, 2012 | Grilling
Burner igniters spark but do not ignite the burners. Do I need to replace them or is there some way to clean something. Also, the rotisserie burner will not ignite, and it has never been used.
All the ignitors work (spark), but none of the burners light ... is usually caused by and inadequate gas supply. Since you didn't didn't mention what the grill is fueled by (Natural Gas or Propane Gas), I going to assume it's Propane. So, turn the propane tank valve to OFF and disconnect the hose from the tank, Wait 5 minutes and reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow) , until it's fully open. Try lighting the burner farthest from the tank first. If it lights properly, turn the burner knob to the highest setting and continue to light the remaining main surface burner(s) the same way. If all lightt and the flame height is as it should be, you solved the problem. If it doesn't, either your tank is empty or the grill hose/regulator assembly needs to be replaced. You can purchase one from any home center or hardware store that sells gas grills. Take your old one with you for comparison.
If it's fueled by Natural Gas, make sure the gas line shutoff valve is turned ON all the way.
Hope this helped you to solve the problem.
Apr 01, 2011 | Ducane 30400040 Stainless Steel Grill
I am in ecuador and have had a local "plumber" install a lpg tankless water heater for me. After more difficulty than there should have been it's up on the wall with the water and gas lines attached but it...
The system is ignited by turning on a hot water faucet causing water to flow through the unit activating the igniter.You could disconnect the gas line at the unit turn the valve on and off real quick and smell for gas.If there is air in the line you may have to let it run or purge the line just long enough to make sure gas and not air is comming out.You might want to have utility company do this if you have any worries .I would make sure it is set up for lpg and not natural gas. And then and this is quite often the problem the gas line feeding the unit should be at least 3/4 inch pipe and fairly close to the main supply and in no instance the last fixture in system unless the pipe sizing is adequate for the amount of gas the unit needs to run.If sizing is the problem sometimes rather than running new pipes your utility company might be able to adjust the pressure comming out of the tank to make up for it. Hope this helps good luck
Jun 22, 2010 | Vacuums
Propane gas flame is not hot. Do I adjust the air
Here is something to try if it is LP Gas:
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Mar 23, 2010 | Ducane Affinity 3100
Jenn Air 740-0141 LP to NG Conversion
If the grill can be converted, it's usually a matter of providing a source for the natural gas and then changing the gas jets for the burner(s) and possibly a regulator, depending on your model. Some grills may require changing the gas burner valves themselves. Kits are usually available from a dealer unless the unit is old.
The natural gas jet will be slightly larger than the propane jet because natural gas doesn't have as high a heating value as propane.
If you do this, check your new conversion for any leaks using a soap solution in a spray bottle.
Just be aware that the grill may not get as hot with natural gas and cooking could take a little longer, but should still work just fine.
Your natural gas line should typically be about 1/2" unless it's huge or is over 50-60 feet away from the grill location. If so, use a 3/4" line. Piping material and methods are usually governed by your local building codes.
Mar 17, 2009 | Thermos Stainless Steel Gas Grill
Gas Switch Doesn't Consistently Turn on Gas Anymore
check the gas line inside for spider webs. this happens when the gas line is disconnected for some time.
Aug 18, 2008 | Grilling
Gas grill conversion
It's safe, but you need to keep in mind that propane burns hotter than natural gas, so you won't need to turn the burners up as high for the same heat. Here's an article that explains some of the differences (but doesn't really answer your question): http://bbq.about.com/od/gasgrills/a/aa030505a.htm
Bottom line -- it's safe if you don't leave it cranked up to high flame. Two-thirds flame on propane should give about the same heat as full burner on natural gas.
Of course, you could change the jets. That would compensate for all the differences between NG and propane, and you could run the grill on full high heat if you wanted to.
Aug 05, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
Grilling Logo
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
