Question about Cub Cadet Garden
Were would i get a clutch part number 753-06347 for a cub cadet ride on mower
  • 551 Answers
SOURCE: I need an owners manual for a cub cadet riding
Go to following site http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051 Then type in model LT1042 and check your serial no. again as I could not get it to come u.
Posted on Mar 31, 2009
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
  • 22 Answers
SOURCE: Electric clutch on my 4 yr old Cub Cadet 2518 was intermittent
check fuse or power it up seperatly with 12volts (battery directly into the two terminals) to see if it is a wiring fault but it sounds like you need a new clutch assembly $$$
Posted on Jun 20, 2009
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
How do i get the pto clutch off of a cub cadet lt2180
you need a impack gun to get the nut off the cluctch it will come right off
Sep 17, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Pto keeps shutting off after several feet
This is either the clutch relay, or the clutch is out of adjustment
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
I need part no. for manufacture date 2005 cub cadet lt 1045 modle ps-sv600 0009 pto clutch
I have a 2005 Cub Cadet LT1042, Spec. No. PS-SV590-0003, but my parts manual also lists part numbers for the LT1045. The clutch part no. given for your model is 717-04174.
Hope this is helpful.
Paul
May 10, 2013 | Oregon Scientific Electric PTO Clutch for...
Cub cadet riding mower 50in blades will not engage
check for power to the electric clutch if no power check the saftey switches
Apr 20, 2012 | Cub Cadet Garden
Cub cadet riding mower 50in bladss will not engage
see if there is power to the clutch if no check the safety switches
is the mower making any sounds when u crank it or nothing at all?
Feb 07, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub cadet zero turn clutch will not engage
If the clutch will not engage it can be that the cable is not regulated to pull the clutch enough
this is an idea on a real car.
thanks
Jul 12, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I need the name or part # for thr pulley right above my clutch and attached to the engine with a bolt on my 07 cub cadet series 1000 42 cut
Type in your model number to your search engine. Find your model and you will see a parts list for your cadet.
Hope this helps.
Aug 05, 2010 | Oregon Scientific Electric PTO Clutch for...
Engine stalls when electric PTO clutch is engaged
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
110 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
