Question about Sony Playstation 3 (PS3) Console
Ps3 joypad doesnt respond
No light or lights were visible on my ps3 joypad when I plugged it in or when I used it as a remote device. I borrowed a relatives joypad that was definately working on his machine but although the lights came on this time when I plugged it in they didnt turn off and reduce to just one light which is what is supposed to happen. I tried it in more than one usb port but still no joy! I have tried reset button at the rear of the machine but nothing.any ideas?
  • deechis Aug 05, 2008
    I bought a new controller.thank you
    Problem Solver:
  • 16 Answers
Your controller may be broken. These controller dont last forever even though they dont use batteries. Sony says the controllers will breakdown in a few couple years. Hope i helped you out
Posted on Aug 05, 2008
Hi, I did a system reset on my PS3 and now none of my controllers will not sync to console, Iv tried resetting controllers also. Could you help please ?
Make sure the controllers are plugged into the PS3 for initial use. Are the red LED lights flashing/lit. If not the battery may be dead. Can you borrow a friend's controller to make sure the controller ports are working correctly?
Dec 27, 2014 | Sony Playstation 3 (PS3) Console
Philips htl2100/12 soundbar doesnt respond to remote control after plugging in
My soundbar won't power up. So I pull the battery out of remote, press a few buttons, put the battery back in and all of a sudden the device can be powered up and controlled. Until next time it stops responding. I replaced that original battery with a new one but the problem still persists.
Dec 10, 2013 | Philips SoundBar DVD Home Theater with...
Need to program my tv and dvd player to the remote
Please follow the steps below
Program the First Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3.Release the Setup button
4.Press the TV button.
5.Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7.If the device responds, you have successfully programmed your Philips universal remote.
8.If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
6.Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7.When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To get the universal remote codes please visit below solution
http://www.fixya.com/support/t5395701-universal_remote_code_phillips
Thanx
Jul 27, 2010 | Philips Universal PH301S Remote Control
My screen is frozen in updates. It tells me to press ps button to use my controller. What is this?
Its the very middle button on your playstation remote. If its saying press the ps3 button on your control its possible your ps3 is not frozen but your ps3 remote has just turned off..
Press the very centre button and check the lights on the top of the joypad. Are any lights lit solid? Once the light comes on solid the controller is active. If these do not light youll need to charge your ps3 remote with the usb cable that came with the ps3.
Also if your ps3 remote is lit for number 2, hold down the ps button, very middle for about 5seconds. Should have an option for reassign controllers, select that and put your controller to number 1.
Hope this helps
Apr 20, 2010 | Sony Playstation 3 (PS3) Console
Im trying to set up my blue tooth to work on my ps3 but no signal is found what am i doing wrong?
You need to pair your PS3 with your bluetooth headset.
  1. Turn on your PS3's bluetooth and search for bluetooth devices.
  2. While the PS3 is searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the PS3 finds it.
  3. Pair the devices and allow the BT headset to connect automatically.
  4. To connect, press and hold call/end button on BT headset like the one in step 2.
Oct 25, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
I can't get remote to charge. It is a sixaxis sony
swap lead into other usb port, if possible try another lead and joypad........you will have to eliminate the lead and joypad.
let me know
thx
Aug 02, 2009 | Sony Playstation 3 (PS3) Console
Force gt wheel doesnt steer, everything else works fine?
The wheel should be plugged in and powered up before turning on the PS3. While booting the wheel should go through its full range of motion and the horn button light will stop blinking and stay on steady. If the light doesn't stop blinking the wheel failed to calibrate and is probably defective. I had to exchange mine and did end up getting one that worked this time.
Jan 10, 2009 | Logitech Driving Force GT Wheel for...
Game freezing
PS3 is one of the most amazing gaming device but like other competitorgaming devices (Xbox and Wii) It also has some problems like Freezingup. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
Problem with the ps3 loading
Sounds like you need to format your hard drive, if your system will not let you do this you may need to remove the drive and either use another PS3 or connect it to your PC, the PS3 uses a SATA drive like the drives found in laptops, it is formatted to FAT32, if you need to back up data you can either use an external memory device connected to your PS3 and use the backup option in menu or if that is not possible due to tech problems with the console connect drive to your pc and copy all data to a folder, please remember that the drive is FAT32 if you format on your pc, the best way to connect the drive to your pc is with an external HDD case, borrowing one rather than buying would be a good option, anyhoo so either way you have formatted your drive you replace it and now the system should say it is formatting again this is fine just let it do its thing, if you want a stable way to update visit the official site and download the latest updates for the PS3 and place onto an external memory device and connect to the console and update from there. I hope i have atleast shed some light on the problem if nothin else good luck and be lucky :)
Nov 13, 2008 | Sony Playstation 3 (PS3) Console
Sony ps3
you use the remote play setting to set it up
Mar 10, 2008 | Sony PlayStation Portable (PSP) Console
Sony Playstation 3 (PS3) Console Logo
75 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
