Question about Dryers
HI,SEEMS TO BE ONLY HALF OF MY HEATING ELEMENT IS WORKING.THE MACHINE WAS BROUGHT IN 1998,CAN YOU TELL ME HOW TO FIX IT,WITH PICTURES IF POSSOBLE THANK YOU
Not sure about the dryer problem, but you might want to check your "Double-Pole" 30 amp breaker in your electric panel box. Sometimes one pole can go out and still work with only 110 volts going to your dryer. This would result in only partial(one-half) of the necessary electric power for your dryer to work properly. If yor're not sure how to check it, then call a qualified electrician. Don't take a chance on electrocution!!!
Posted on Mar 13, 2011
Model WF-R125AC. Why does it wash for about 15 minutes, then displays "98 minutes error HE2"?
Hi There. HE2 is a Samsung error denoting a fault with the machine not getting up to temperature. While there's a tiny possibility that the problem is with the relay that powers the element or the main control board its self, 99% of the time this is down to the heating element failing. From what I can tell, the machine takes a fairly generic heating element and you can buy them on eBay around £20. It's a fairly easy fix once you have the element, you can probably find a video on You Tube I would imagine
Sep 20, 2015 | Samsung Washing Machines
Have a 1996 buick park avenue heater works only on half the car passanger side has heat driver side cool air the defrost to vent to floor doesent work check for vacume to heater switch no vacume at all...
you can have relay fan faulty, blower, or heating elements or duct NOT o.k .However you can go to www. aa1car.com get the topic and fix it.
God bless you
Nov 20, 2013 | 1998 Oldsmobile Intrigue
Hi we have literally just brought a Hoover dyn 7164 d and on first check-which the manual asks us to the error code e03 appears and will not drain!!!what do we do??its full of water!how can something...
What a heap of junk of a machine. The one I own died after 13 months taking the electrics in the house out with it. A faulty heating element was the cause. They leak over their electrics with predictable results. A modified element has been fitted. Avoid this and all Hoover products like the plague.
Dec 02, 2012 | Washing Machines
My dryer is only blowing out cold air?
It is probably the heating element has blown contact ur manfacturer for error code that will tell you exactly then contact them for a service agent
Oct 06, 2012 | Hoover Dryers
The oven does'nt seem to be able to heat up above 150, the fan is working, the bottem half of the oven does'nt seem to heating up. Is this fixable or do i need a new oven?
Hi.
If the part that is not heating is only the bottom element, and the top element is heating regularly, then you may need to replace the lower element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
Regards.
Mar 04, 2010 | Whirlpool RBS275PD Electric Single Oven
What do I look for? Rangemaster Kitchener 110
Problem solved, took the back off the inside of oven and the element had a huge burn hole in it. Brought a new element from the local spares shop £17+vat. Easy to fit and it works better than ever.
Nov 13, 2009 | Rangemaster Kitchener 110 Electric Range
Hamilton Beach Brew Station
My brewStation 47214 stopped pumping water today, even though the warming element continued to get hot. A half dozen screws later I discovered a second heating element inside the coffee maker. The internal element is what heats the water and forces it into the basket. This element was burned out, religating my brewstation to the garbage. Probably last 3+ years.
Jul 11, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Hotpoint Aquarius Condensor Dryer not getting Hot
I don't know Hotpoint models but I do know Malber models very well which also have a condensing dryer. The dryer has a fan and a heating coil or heating element, similar to a hair dryer. If you are getting no air flow, then it could be the fan. If you are getting air flow but it is not hot, then it is probably the heating element which burnt out. In the Malber machine, the top cover comes off and you can see an aluminum duct on top with two terminals sticking out the side. These two terminals go to the heating element inside the duct, and the heater element is like the heating element in an oven. You have to remove the duct and then it splits into a top and bottom half, and then you can remove the heating element to replace it. The way to tell if it is bad is to run the machine in a dry cycle and see if there is 110 volts across the heating element terminals. If there is power, but no heat, then the heating element is bad. That element is usually the first thing to fail.
Feb 11, 2008 | Hotpoint NVL333EY Electric Dryer
Won't heat water anymore - only washes in cold water
u need to take the back half panel off once off u will see the two thermostats and the heater element you can test the element by undoing the wires and getting an old wire with plug on 1 end and bear wires on the other place corrisponding wires to were that wire had come of turn plug on and if it is working it will heat up straight away which means the thermostats need replacing if it doesnt then the element needs replacing
Feb 07, 2007 | Zanussi FLA1001W Front Load Washer
Dryers Logo
Top Dryers Experts
