Question about Maytag Washing Machines
A white stain or powdery residue remains after washing dark colors
    Scholar:
  • 158 Answers
This often occurs as a result of overloading the washer. If a washer is overloaded the water cant get in between all of the clothes to thoroughly rinse them out. That will cause streaks of white (which is most likely the unrinsed detergent).
Also, make sure you are using the correct water level setting for the load size.
If a washer is overloaded continuously it will cause premature parts failure.
Other cuases can be related to water hardness and the type of detergent you are using.
Try using a detergent with smaller granules or even a liquid detergent.
Make sure you are not using to much detergent for the load.
One other thing, turn the water off to the washer, remove the hoses from the back of the washer and check the screens that they are not corroded, if they are replace them. You can get these at Ace hardware, lowes and maybe even wal-mart. Corroded screen will impede water flow hense not allowing a good water flow during rinse cycle.
Posted on Mar 13, 2011
I have a Cabrio platinum top loader (not glass) & dark clothes come out with white powdery residue no matter how little he detergent I use and clothes come out really wrinkled
Aha! the problem i'll guess your model number is wtw8200ywo-you have a very bad washing machine-i'm sorry-it does what you say darks are covered withresidue and clothes are very wrinkled-if you are not happy with these issues take it back and get another brand of washer-I have a maytag-maytag was bought by whirlpool-I've had problems with this machine only a year and a half old so probably not a good choice either-Research before you buy and let me know who you come out-cheers Denny
Oct 22, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Calypso stains load
Hi there
I wonder why "dark streaks" on white towels. I presume that you have made sure that there is no dirt flying around in the machine.
Try to let the machine go a circle -without any washing in it- just to see if the water takes color. There are also in the shops washing powder
that remove stains of different types.
Also powder for "only whites"
good luck
Kolbrun
Apr 23, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Black Crayon marks in lt colored couch and floor
try using a cleaner called goo-gone, it disolves a multitude of different oil and wax based staind and marks I use it to remove gum from a dark green couch and then a white carpet. Both stains are gone no residue, it has a citrus smell that fades with regular soap and water after te stain is gone.
Feb 11, 2011 | Garden
Soap stains on dishes
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jun 03, 2010 | Frigidaire 24 in. GLDB957A - Multiple...
Adp242 do not wash everything remain stain the
Make sure that water is entering the machine as the first operation--open the door to check shortly after you hear the wash cycle come on. Water should be dripping from everything. If there are several inches of water sitting in the bottom, but nothing is wet, and you have heard the pump running, you will need to tear down the lower spray arm assembly down to the deck to clean the large intake screen at the bottom. Keep track of orientation and placement of each piece removed. Remove the large screen and soak it in hot water/white vinegar/detergent solution for an hour or so, then scrub the screen to help remove deposits. Inspect all holes in the deck surface for plugging--a wet/dry vacuum will remove most of this debris. Reassemble everything in reverse order. Inspect the spray arms for any plugging of holes and for any split seams. With luck, this should fix your problem.
Nov 28, 2009 | Washing Machines
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I ran a load on "sanitize" and some of the clothes came out with red stains under the arms!!! I assume it is where residue from deodorant remained. The items were from 3 different people (using different...
Doubtful, sounds more like somthing red was in the wash with the clothes a wrapper of somekind Deodorants use alunimum in their makeup so it would be white and powdery not red.
Sep 07, 2009 | LG WM2688HWM TROMM SteamWasher
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My washing machine is leaving little residue on all my clothes after a complete wash, What are they? and how do you get rid of it, the washing machine is not yet a year old
Describe the residue. If it's oily (black, dk green) then the seal is out of the tranny and oil is getting into the tub. Dry cleaning is best for oil based stains. Liquid dish detergent is good also. On white it is tough to remove. Your washer will need a new transmission or replacing.
If it is powdery I'd guess a soap buildup, especially if you've recently changed detergents. The new detergent is breaking up the old soap scum in the outer drum and it is redepositing onto your clothes. This should wash out/off.
Tip: If it's a soap residue, fill washer full without clothes with hot water. Add 1 gallon white vinegar and more hot water until the unit if as full as possible. Agitate 15 minutes and drain. Rinse with a full level and drain.
Jan 24, 2009 | Samsung SW62ASP Top Load Washer
Front loading washer leaves stains
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Nov 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
112 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
