Question about Kenmore Refrigerators
Refrigerator is freezing liquids and food. I have turned thermostat down to low and adjusted air flow to max for freezer. What else?
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Mar 13, 2011
The freezer section of our Danby DFF8200W freezes well. However, periodically the refrigerator section freezes everything in it with the temp control turned as low as it will turn for me. The dial does not...
Make sure you clean the backside of refrigerator at bottom from dust. Make sure you have the recommended clearance from wall. Also make sure the food in freezer and frige have clearance to allow air to circulate around food. Keep playing with your controlls...The dails might be on wrong
Aug 11, 2013 | Danby Refrigerators
KITCHENAID SIDE BY SIDE REFRIGERATOR FREEZER DOES NOT FREEZE LIKE IT SHOULD BE. STILL WILL MAKE FEW ICE FROM THE ICEMAKER BUT DOES NOT FREEZE LIKE IT SHOULD BE, REFRIGERATOR IS AT ITS MAX TEMPERATURE WHEN...
Clean condenser coils, remove anything around refrigerator that might prevent air flow on coils. Make sure freezer and fresh food area door are completely closed.
Aug 01, 2017 | Kenmore Side by Side Refrigerator
Fridge is freezing all liquids freezer is turned down as low as possible and liquids are freezing
heatman101
Feb 24, 2011 | Magic Chef CTB1922 Top Freezer...
Refrigerator freezing food
Ah... where is that manual when you need it! Actually, the internet is WONDERFUL for such emergencies! I found a manual on the FixYa site for you in pdf format. It will be easier to find on your computer!
Now to the soluiton...
Generally with the top freezer designs the main thermostat controls the temperature of the freezer (which should be about -18°C or 0°F and the there is a slide control that allows a metered amount of cold air to drop down into the "fresh food" compartment.
As an immediate adjustment, turn the "Fresh Food" slider down 1 number LOWER that what it is set to at the moment. Is fresh food still freezing? Then put it down another number lower.
But you should also check the temperature of the freezer compartment with some appliance thermometer... leave it in for several hours or overnight for a proper reading if you've just added food to the freezer. It should be around -18°C or 0°F If you adjust the freezer, you may have to go back and readjust the fresh food setting.
I hope this helps! Don't forget to download the digital manual!
/denis
Dec 10, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Frs23h5asb6 is freezing food on refrigerator side. Turned refigerator control off, still is 33.5 deg. Took out all bags to increase air flow. Is thermostat bad?
first of all are you talking about summer or winter, i dont know what state you live in. the weather and humidity play a big part on your unit,is your kitchen as warm as in is is winter,if not turn down the freezer control down ,turn on refrigator control 1/4 of the way.until you get both sides of the unit working at the right temperatue.you may have to adjust the settings a few times.using the freezer and refrigerator controls back and forth. also in the summer you can usually back down the controls to adjust in the temperatue change. no more frozen lettuce in your fridge,i hope.,,,,,,,,dave
Jan 25, 2010 | Frigidaire FRS23R4A Side by Side...
Whirlpool Model ED5SHAXML12 is freezing food in refrigerator even when dial is at off. Happened from one day to the next.
At the refrig controls , the freezer control , controls how much air goes into the refrigerator section . Open the refrig door , and up at the top left , put your hand over the damper (air vent) . Turn the freezer control from high to low , and feel the difference in the air flow . If you turn your freezer control to a lower setting , less cold air will enter the refrig . Think of it as : the freezer control adjusts the temperature , and the refrig control , tells how long to run the compressor . In actuality , this is how it works . However , with the dial (refrigerator thermostat) in the off position and refrig still running , this indicates a bad thermostat . Pt # 2198202 .
Sep 09, 2009 | Whirlpool Refrigerators
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Refrigerator does not get as cold as I would like
First check the condensor fan and condensor for dust and make sure they are clean. If these areas are not clear the system will not operate correctly. You should be able to place your hand down low on the front of the frig and feel warm air coming out of the grate there. The presence of a flow of air meens that the condensor fan is working. Depending on how forceful the air flow is, would depend on how much dirt and dust the condensor has collected. The temp controls should be set to midway first. There is a dilicate balance for these settings. Over adjusting can cause problems. Then after several hours check the frig. If not cold enough. Adjust only the fresh food adjustment colder a little bit at a time. Repeating this untill your fresh food side is cold enough. If you over adjust the fresh food side too much then food in the fresh food side will begian to freez. If you set the freezer side too high you may be causing too much frost build up on the evaporator and lowering the air flow to the fresh food side and causing it to be warmer than it should be. This would be a check to see if you can balance the frig temp. If you can`t get it to balance and there are no restriction of air flow in either the evaporator or condensor, then we may have to look farther into problems with the compressor. You may need to check for some ice buildup around the air inlet in the fresh food side from the freezer side. Try this and let me know how it is.
Nov 13, 2008 | Whirlpool ED5FHEXMQ Side by Side...
GE PSS26MGPWW
Yes the refrigerator knob is just a damper between the freezer and the refrigerator. All the heat removal is done in the freezer section. it just dumps air through to the refrigerator. So drop the thermostat down to about 5 and try that. If food is still freezing
drop the thermostat a little more. If food continues to freeze then your thermostat could be bad. Not sensing temp properly and allowing the refrigeration system to run to long.
Hope this helps
May 23, 2008 | GE PSS26MGPWW Side by Side Refrigerator
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Refrigerators Logo
157 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
