Question about Fender 2232200000 Blues Deluxe Reissue Guitar Amp
Fender blues deluxe reissue is making a popping sound
  • Fender Master
  • 5,603 Answers
Try tapping the tubes (especially the small ones) lightly with a regular wood pencil and see if you can detect noise. Also verify your guitar AND cable are not the source of the noise by using them on another amp. Verify that popping exists witout guitar cable being plugged in.
Also this is the season for static electricity. Shuffling shoes on rug may create pops due to discharges. Spray rug with Staticide if this is the case.
Posted on Mar 14, 2011
I replaced Can I change the tubes on my fender blues deluxe reissue from 6l6 to 6v6 power tubes
An internal component has failed. Without it in front of me for testing I cannot say which. You need to takje it to the repair shop.
Jan 28, 2016 | Fender BLUES-DELUXE-REISSUE Tube Guitar...
Is this a 61 Reissue? 121100384Serial number
Not sure to exact model guitar you are referring to
Fender, Gibson, etc...?
I do know that it looks more like a reissue #
if it was Not a reissue it would have a lower number Vintage Guitars Info Fender collecting vintage guitars fender stratocaster... Vintage Guitars Info Gibson collecting vintage gibson guitars
Mar 25, 2015 | Gibson Custom Historic Reissue SG Guitar...
I have a Blues Deluxe it has started making a in and out sound similar to higher pitch hum but in and out at a constant pace
check out your tubes....it sounds like one is working its way out of its socket or you have a microphonic tube...may be time to replace them and have the amp serviced while you are at it. ...Does one tube have a whitish look? inspect them/.....are there any cracks? while it is on...tap them with a lead pencil...something NOT metal...does it make a loud noise? These are all indicators there is something going on with your tubes..Good luck
Feb 26, 2015 | Fender 2232200000 Blues Deluxe Reissue...
Why is my Fender Blues Deluxe Amp making a crackling sound without an instrument even plugged into it and when I do plug in, it quiets when I touch any place on the guitar?
You probably need a new input jack on the amplifier. When they get loose the connecting wires can crackle, but plugging a guitar in stabilizes them (no more crackle).
Feb 11, 2015 | Fender Blues Deluxe Reissue Tweed Combo...
Is there any way to use a heil talkbox with a fender '65 deluxe reverb reissue?
No - you use these with a microphone. Plug you guitar into the Heil, put the tube in your moth and sing into a mic while playing. You CAN plug the microphone into the fender amp, but a PA system is better
Oct 15, 2013 | Dunlop Ht1 Heil Talk Box
My Fender Hot Rod deluxe makes a popping noise when switching back to the clean channel.
This is because your clean channel only runs through the pre-amp section, requiring an increased volume level to match that of the volume of the drive section which is overdriven by the pre-amp circuit. my suggestion is to use lower volume level on the clean channel of the amp. To get any volume boost you may need to match the two channels you could use a signal/volume booster or overdrive pedal between your guitar and amp input, switching it off and back on when you switch back and forth between channels.
Jul 15, 2012 | Fender Hot Rod Deluxe Guitar Combo...
Fender passport 150 pro- Bought to uses for "Bike Nights" Plaing cd palyer in small retail parking lots. Volume is too low, when ever I try to put input level beyond halfway,,, I get...
You are in danger of popping the amp. The Fender passport 150 would be capable of covering about only a 20 foot by 20 foot area. If your area is bigger than that, you need more power and certainly bigger speakers. I would NOT recommend the larger Passport systems as the speakers are too directive for what sounds like your use... also there are reliability issues.
Aug 05, 2011 | Fender Passport Deluxe 500watt Sound...
Unable to activate reverb and drive channel with either cabinet switches or footswitch. Brand new out of the box so it must be something I am doing.
Make sure you have the CORRECT foot switch pedal. Try unplugging the pedal and then try the cabinet switches to see if they work. The pedal for this one has a different circuit than some. I have the schematic and we can do further testing.
Dec 28, 2010 | Fender 2232200000 Blues Deluxe Reissue...
Popping sound when amp is on. A steady pop,pop,pop pop. Fender Hod Rod Deluxe. It vibrates the whole amp. Lights dim with each pop.
You don't say WHICH lights dim with the popping. IF it is your lights in the house, IMMEDIATELY get an electrician to check your wiring as there is a loose connection or failure someplace in the sytem that would be a fire hazard.
IF the lights you are talking about are those on the amp, there is a power supply failure in the amp which is LIKELY a bad filter capacitor. Take in for repair or learn how to work on the eloectronics safely and do the repair yourself. The part is likely under $5,
Feb 12, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Fender 2232200000 Blues Deluxe Reissue Guitar Amp Logo
302 people viewed this question
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
