Question about HP ScanJet 2400 Flatbed Scanner
Reduce the width & height
Good Afternoon, Sir
1. My problem is uploaded image & file have widht =1699 & height=2339. Please reduce the width=710 & height upto 890.
2. Resolution is 70 to 75 dpi & preferable size is 300k.
3. Please sir, solve my problem.
Thanks
Ravi
  • 876 Answers
Open the image in your picture program. click on the option to resize your image which is generally under the heading image depending upon which program you use.. change the dpi to 300 and the PIXELS width to 710. that will automaticaly give you a height. If the picture is "taller" than you want you will need to crop it to get it under 890. Be sure to keep the ratio the same while you are making the changes. there is usually a little box regarding ratio that should be checked. Good luck.
Posted on Aug 01, 2008
How do I minimize jpegs in a power point file
Right click on each image file -> open with -> Microsoft Office Picture Manager -> Picture -> Resize -> Percentage of Original Width and Height -> select an appropriate size reduction percentage -> OK -> File -> Save As -> name new resized image -> Save -> upload resized file to presentation.
Nov 12, 2011 | Microsoft Office Professional 2007 Full...
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Sending photos as an e-mail attachment
When sending photos as e-mail attachments, the image (file) size should not be too large. Use the included image viewing program called Image Expert to save photos in reduced size. For instructions on installing Image Expert, see "Installing the image viewing program" on page 42 of the Instruction Manual. 1. Launch Image Expert. 2. Choose "Open Image" from the "File" menu. 3. Specify the image you want to reduce, then click "Open". If the camera is connected using the USB cable, it is displayed as a removable disc. images on the camera can be opened directly by specifying the remove-able disc. 4. Click on "Change Size" in the "Image" menu. 5. Input values at "Width" and "Height", then click "OK". If "Keep Aspect Ratio" is checked, the size is changed without changing the image’s vertical:horizontal ratio. 6. The image is displayed at its new size. 7. Click on "Save As" in the "File" menu to save the image with the new size.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
How do I make an image file smaller so I can send it by e-mail?
To make an image file smaller for e-mail transmission, change the image file size in "Exif Viewer" or "FinePixViewer". Changing the size of an image file 1. Start up the Viewer and select the folder containing the image you wish to send. 2. Double-click the thumbnail for the image file you want to resize to open the image in its own full-size window. 3. Select "Image size" in the "Image" menu. 4. Set "%" as the "Unit" used for file size display. Then enter a value lower than 100 as the "Width" or "Height" and click the [OK] button. 5. Select "Save as" in the "File" menu to save the image. (You can also reduce the image file size by lowering the quality in "Save as type".)
Aug 30, 2005 | Fuji FinePix 2400 Zoom Digital Camera
What is the procedure for sending pictures over the Internet in FinePixViewer?
Aug 30, 2005 | Fuji FinePix 2300 Digital Camera
Aug 30, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Aug 29, 2005 | Fuji FinePix 2600 Zoom Digital Camera
HP ScanJet 2400 Flatbed Scanner Logo
80 people viewed this question
Ben Johnson
