Question about Canon PIXMA MP610 InkJet Printer
Printer was working O/K last time I used it, turned it today and it tells me that there is a printer error and shows code A600. Have tried turning off and on as suggested and this has not worked. please help thank you
    President:
  • 287 Answers
Hello and Welcome
I am Angel Bird and i will be assisting you regarding the issue
The A600 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,It usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.The purge unit,called a spittoon assembly in an Canon, HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing,That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow, Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma MP610 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
printer was working O/K last time I used it, - angel_bird_5.jpg
If you didn't get it and have confusion to solve it yourself then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution was helpful for you. Please Rate my solution it if it helps you.
Thanks & keep usin FixYa
Posted on Mar 13, 2011
I have a Fujifilm Finepix A600 and when I turn it on I get CARD ERROR Can you tell me how to fix it
You may have improver card fitted. Please remove and re fit the card. If problem persist , please try another good / new card. If you have no problem with new card, your existing/previous card is broken.
Regards,
Apr 19, 2011 | Fuji FinePix A600 Digital Camera
Getting error code on printer screen A600 why does
Mine kept doing that. My dad found website where lots of people had turned it upside down, shook it and then was fixed, so we tried it and it actually worked!! Now is printing again and no error codes!! Worth a try!!
Feb 09, 2011 | Canon PIXMA MP600R All-In-One InkJet...
A600 error or Canon Pixma MP780. Now it won't even turn on...like no power is getting to the printer. What's up?
Hi there
Error A600
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
The 6A00 is a Canon generic code for paper path jam.
Almost 90% of the time is related to the purge unit being jammed with something and not being able to move.
Look for paper, paper clips, push pins, screws flower bud pods or the like.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow.
The purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail.
You can try moving it back and forth about 5 times or so and clean the rail with a cleanex and putting a little bit of some light oil on it and then close everything up and try it.
If you found this useful all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 19, 2010 | Canon MF4150 Laser Printer
The printer screen shows "Error A600" and the printer will not work - what can I do?
Hi there
Can only try.
Error A600
Feb 11, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Shows error 6A00I turn it off and on and it doesn't fix it. What do I have to do?
Hi there
Please try this may work
Error A600
Feb 10, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Shows "error A600" and will not operate
Hi there
Error A600
Oct 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My ip4300 printer shows - Service Error A600-
goes through this link and try.........
http://tricks-collections.com/solution-canon-pixma-ip4300-error-6a00/
Oct 07, 2009 | Canon Office Equipment & Supplies
Cannon MP810 when turn on display error A600. There is also no light displaying on the printing cartridge.
A600 or 6A00. If 6A00 then the fault code is for the AP motor position error. Error lies with the sheet feed unit, Purge unit or Logic board.
http://www.tradebit.com/filedetail.php/4588588-canon-pixma-mp810-printer-service-manual
This is a complete service manual
Sep 14, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Jan 02, 2008 | Fuji FinePix A600 Digital Camera
C00f0401 error code
I have a solution that works.
But first the background: I have an older model HP G85 printer that's a real workhorse and I love it but when I lost power that c00f0401 code came on and I couldn't clear it. So I called HP support and found them USELESS. A search of the Internet tells you to hit the #6 keys to clear it. Some say hit #9 to clear it and others say to hit #5 keys and still others tell you to disconnect the 'self-feeder' tray cable. I eventually cleared it by hitting the #9 key while simultaneously pressing the ON button. I did that about 50 times then it cleared itself and worked fine for a year. However last week I again lost power and when the power came back on again I couldn't clear it no matter how many times I tried.
SO HERE'S MY LATEST CURE and it worked several times in a row--so I think it will always work in the future.
1. Turn printer off
2. With your left hand hond down simultaneously the 5, 6, 9, and # keys an rhytmically press those keys up and down, up and down, (at the rate of about 3 times a second). AND AT THE SAME TIME: Use a finger from your right hand and press the on/off button rhytmically (at the rate of about 3 times a second). Eventually the INITILIZING light will stay light---then take all your fingers off all keys.
3. After waiting a short time (a minute or son) the computer initializes itself and it works fine.
Anyway, it worked for me each time I tried it. I hope it works for you.
Dr. Campbell
Computer Science Dept.
Dec 31, 2007 | HP OfficeJet V40xi InkJet Printer
Canon PIXMA MP610 InkJet Printer Logo
546 people viewed this question
old marine
old marine
