Question about Kenmore Refrigerators
I have a Kenmore model# 253.73754300. The problem I'm having is the freezer works but when it goes into the heater/defrost mode, it won't shut off the heater . The freezer compartment will get completely warm nearly hot, defrost everything and then after a while the cooling system will restart to freeze again. It will then work normal until the next cycle when it happens again.Would the problem be the thermostat or timer switch? Or something else completely? and how do I access these things to change either? Inside the compartment or from the back?
    Master:
    Sergeant:
  • 385 Answers
It sounds like the Termination Thermostat is bad , it's job is to turn off the defrost elements.You can get to it from the front inside the freezer. It's a small disk about the size of a quarter and about one inch tall. It will be attached to the evaporator coils. Be careful when taking it out not to damage the coils.Take it with you the parts store so that you get the right replacement.Be sure to unplug the refrig. before starting!!!!!
Posted on Mar 13, 2011
  • 87 Answers
SOURCE: Refrigerator
Have looked at the schematics for this cabinet and am unsure as to the location of both defrost thermostats as unclear on drawings. The purpose of the defrost thermostat is to overide the heater and end the defrost cycle, once the temperature on the evaporator is high enough (normally around 0'C). If you have two then one will probably control the heaters going off and the other may well control the fan, for coming back on. I.E. once the defrost has ended the second sensor will tell the fan when the coil is cold enough to come on, this prevents heat being pushed into the main area after a defrost cycle. If you feel competent enough then I would bypass the heater thermostat temporarily and see if the heaters kick in. The other thing to check is that you have a resistance across the two ends of the defrost heater. In my experience the heater is the most likely to fail, the sensor sometimes fail and the timers rarely fail. The age of your cabinet would suggest the heaters. Please do not leave the sensor bypassed as it performs an essential role. Hope this helps.
Posted on Sep 05, 2007
22yooper
  • 828 Answers
SOURCE: Kenmore 596.72913200 Refrigerator is Warm,freezer not freezing
The frost on the back wall of the freezer with a new timer installed indicates that the problem is beyond the timer in the defrost circuit. In this circuit you have a defrost heater and a defrost thermostat. One of those two is your problem.
If you have an ohm meter available and have the knowledge how to use it you can access the heaters by removing the back panel wall of the freezer section. Disconnect the heaters from the circuit and read the meter for continuity. If you read Ohms through the heater(s) your problem is in the thermostat.
Posted on Jun 08, 2008
Maanita
  • 1142 Answers
SOURCE: Trying to locate Defrost Timer GE PSS27NHN
the defrost timer looks like
Posted on Aug 07, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Kenmore model 253 fridge cools then issues....
Ye, try to first replace the Relay, if that does not help then go to the run capacitor. Those are going to be your only 2 problems that you will have as long as the compressor is still doing its job by atleast running
Posted on Feb 09, 2009
  • 108 Answers
SOURCE: Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Posted on Apr 27, 2009
Won't defrost it's a 1990 Kenmore model # (106) 9608281
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Jul 10, 2011 | Kenmore Refrigerators
Need manuel for a Kenmore frostless quick freezer model #253.9280410
I don't have a manual but these are fairly simple. On the back inside below is a defrost heater and terminator sorta like this:themobilian_747.jpg
The cold control maintains the temp and their is a timer that either puts it in run for 10 hours or defrost for 21 minutesthemobilian_748.jpgThe compressor relay goes out on these. The defrost heater or defrost heater termination themostat can cause defrost failure if bad.Not much to these babys.
Jan 07, 2011 | Kenmore Freezer 11.6 cu. ft. Upright...
Kenmore side by side doors. Air is blowing weak not cold
DEFROST PROBLEM
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Feb 04, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer working, Refridgerator lost coldness. Found frost buildup in freezer, which is on top.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Dec 29, 2009 | Kenmore Refrigerators
Freezer is working but fresh food area not cooling. Back wall of freezer has frost build up.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
Dec 01, 2009 | Kenmore 63822 / 63824 Bottom Freezer...
My refridgerator evaporetor coils are freezing up. is there a relay that the micro control computer sends a signal to to send the refridge into auto defrost. it is a kenmore model 10654209300. Bobby
Oct 23, 2009 | Kenmore 54202 / 54204 / 54209 Side by Side...
Oct 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 70102000 refrigerator is not freezing food hard and bottom not cool enough
May be the beginning of a defrost problem
Oct 13, 2009 | Kenmore Refrigerators
3 year old kenmore top freezer, won t defrost ''no ice'' buildup behind the freezer panel I removed. no clicks on the defrost test, same result for method #2. The ice maker works ok when freezer is at...
your freezer had a heater and a bi metal behind its pannel. if they won't work properly than you would face problem like this.......contact your service authority. it cannot be solved by your own
May 14, 2009 | Kenmore Refrigerators
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
196 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
