Question about LG Washing Machines
Hi, I have LG washer and dryer combo WM3431HW. How can i remove lifter (part#4432er2004a) from drum, and is there a substitute part? Thanks.
  • 1,543 Answers
When I check your model number, the lifter comes up as part # MFE38265101
Changing one,...... oh, you really got to want to. On a difficulty scale of 1 - 10 for repairs on this washer / dryer combo, I would rate it about a 10. Basically, you have to remove the motor, remove the entire outer drum, seperate the halves of the outer drum allowing removal of the inner drum, and eventually removal of the lifter from the back side of the inner drum. If you can do the job in under two hours I think you would set a world record.
Posted on Mar 13, 2011
I have a lg combo model wm3431hw/01 it will not start dead
hSee my reply to tumble dryer not start all of what i said about that problem applies to washing machines too. also add door switch and motor brushes.
Nov 04, 2014 | Washing Machines
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front door is locked and I cant get my clothes out.
Check this link, and click on the right side, for the pdf file, to read the manual. Hope this helps.
Mar 29, 2010 | LG WM3431 Front Load Washer / Dryer
Where can i find a free service manual for LG WM3431HW?
Unfortunately you won't find one.
LG only supply their servicing manuals to their repair centres and strictly enforce their copyright, so the manuals are not available to the public and when they do occasionally appear the material has been stolen.
Usually I'd recommend a generic repair manual such as the one by Haynes, but LG's direct drive system and a number of other unique technical features mean that the Haynes book isn't as useful as it could be. The WM3431HW is a large capacity and technically advanced washer dryer so it's certainly not as straightforward to service as a traditional front loading washer or dryer. Many LG spare parts can also be difficult to source outside of their own approved servicing organisation.
I respectfully suggest that you either get LG to fix your machine or post a question on this site describing the problem to see if we can assist you.
Mar 26, 2010 | LG WM3431 Front Load Washer / Dryer
LG WM3431HW is flooding the room
take the lid off
check your inlet valves are they ok
take the back panel off and check all your hoses
find out what is leaking and then i can help you to take apart further
make sure that you unplug it first though.
Feb 12, 2010 | LG WM3431H Washer and Dryer
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
Sep 29, 2009 | Maytag Dryers
Washing Machines Logo
200 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
