Question about Kenmore 22422 Top Load Washer
Achine won't complete cycle. After wash cycle it doesn't drain the soap out to begin another cycle. PLEASE HELP
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
My Bosch Nexxt Front Load Washer doesn't complete the fully wash cycle some times. It first happened with when I washed my sister's family's wash. It kept stopping in the middle of the wash...
(no promises but it's worth trying this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 16, 2011 | Bosch Exxcel WFX 3267 Front Load Washer
My Bosch washing machine model WFMC2100UC has been giving alarm code E04 and the indicator light "rinse" is lit. The manual suggests that the pump or the drain is blocked, this is not the case,...
This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing mashine does not drain completely after
mam
there is a filter it will be blocked please clear it then see its draining also check if there is drain pump if its there it should work.drain pump is located at the back of the machine and the filter at front of the machine.
Sep 07, 2009 | Whirlpool Washing Machines
Dishwasher does not complete cycle
The solution i'm going to give you might sound weird but it should work. The drain hose should have a curve of about 36 inches up and then down to the drain. This avoids the water to drain on its own, the water has to be forced out by the washing machine. hope it helps.
Jan 19, 2009 | GE 24 in. Profile PDW7800 Built-in...
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer problem
Inspect the drain hose, see if there is any obstruction.
Try to understand if the machine does not drain at all or if the cycle is not completing , and timer stops before completinc cycle.
If the machine is not draining, then, once you check the drain hose and see no obstruction in there, it can be a faulty drain pump, or a faulty water level switch. If machine instead does not complete the cycle, it is a faulty timer/programmer.
See here for more detailed explanation: It won't drain
Sep 08, 2008 | Kenmore 22422 Top Load Washer
2007 Bosch Washer WFMC 3301
It may be possible that you are using too much soap. There is a turbidity sensor that checks for soap in the water. It will keep rinsing until it thinks the soap is gone. You did not state if you are ever able to complete an entire cycle or not. If the cycle never completes, it is possibly a problem with the main circuit board. Have you allowed the machine to complete a cycle?
May 18, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Kenmore 22422 Top Load Washer Logo
14 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
