I have no sound on my computer
When I uninstall the sounddriver det computer find the product, and I start install, when it's finish it comes a text: This unit cant start.(code 10)
anyone have a solution for me?
my sound drive is not working.
  • 167 Answers
You need to download a newest driver for your sound card. Driver you have are not good or missing some files.
good luck
Posted on Aug 01, 2008
2 Suggested Answers
SOURCE: I have no sound on my computer
I also have the same problem of not having sound in my system. Please do something about this as this may spore market for you in Nigeria.
Posted on Jul 11, 2008
How to install sounddriver in VIA8235 chipset computer?
Start > Run > type devmgmt.msc. This will load Device Manager (or load from Control Panel). Find Sound, video, and game controller, and expand. Right click on device (it might have an error icon) and install / update driver.
Aug 30, 2012 | VIA Computers & Internet
CTReg sur missing file CTNJB3.ECD missing file Detector/Njb3.DET missing file Detector/DTCTRMGR.DET missing file Detector/DISC.DET missing file Detector/hdd.det missing file when i install the...
It sounds like some of the program has been corrupted/deleted so you should try a free and very useful tool, CCleaner. It can be downloaded at http://www.piriform.com/ccleaner If that doesn't work you may have to go to the install folder and simply delete it, then from CCleaner run the registry cleaner to fix registry and other system problems. Hope this helps and have a nice day!
May 02, 2011 | Computers & Internet
I don't get sounddriver for vista
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Feb 05, 2011 | Compaq Computers & Internet
My sounddriver not working
Try to uninstall and reinstall the driver back maybe the file just got corrupted, how?
Here' what you need to do:
- Go to device manager
- if your sound card driver is not working then you will see an icon with a yellow exclamation mark this is your sound driver.
- remove it then reinstalled it back by just refreshing the device manager
- this will automatically install the driver back and this should resolved the problem
If not,then you can try to restore your computer back to previous date where your sound driver works, just think of that date and use System Restore
Hope this help:)
Jan 27, 2011 | Computers & Internet
My microsoft office 2007 is not working
Prepare your CD with key. Then you uninstall your Microsoft office first by going to the Control Panel and then by clicking on the add/remove programs. Then click uninstall Microsoft Office. I am recommending this because I know that repairing it would take longer than installing a fresh one. Then after you successfully have uninstalled it, you insert the CD and open setup. You can find the serial as included in the CD in .txt form. You just copy it and enter it when prompted and wait 'til the setup finishes. Easy as 1-2-3! I am not so savvy about computers but I've done it very easily. If you want more information or if you have more questions, don't hesitate to ask me. I'll do my best to help you.
ai-ai
Jul 13, 2010 | Microsoft Office Professional 2007 Full...
Can't install quickbooks pro 2009
Sounds like you have the QuickBooks Database manager running or the Quick Connect feature still installed and/or turned on. Check and see if this is the problem by going to start and then programs and see if it says QuickBooks anywhere. If it does, slide over to see which of the two listed above are on. Then go to your control panel and uninstall the program. Double check to make sure the "quickbooks" catagorey disappears from your programs and then install the new version you wish to keep.
Jul 06, 2010 | Intuit QuickBooks Simple Start Edition...
Cant find any sounddevice. No sounddriver.
First download a small program called Unknown Device Identifyer Run on your laptop and click on the sound device hardward if there is one and Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Jan 23, 2009 | Compaq Audio card Sound Card
List the name & model No# of the laptop & the name of the sound device found in either your manual (prefered) or on your CD. Thank You.
Feb 23, 2008 | Toshiba Satellite A135 Notebook
Hey Pekka,1989 did your motherboard supported the sound card that you bought?...if not supported to your motherboard, you must install the cd driver of your sound card..
and to you, hellojollyji, and kauntey?...is that also a sound card?..or a built in soundcard?....if buit-in sound, right click the "my computer" and go to "properties", then click the "hardware", then click the "device manager", in that case, you will all components of your motherboard, find the "sound devices", then if you saw a "yellow question mark", that means, you didn't install the driver of your sound..BUT, but if there's no "yellow question mark"in that device...follow this instructions, have you see the digital clock at the right bottom of you PC?...have you seen the "speaker logo",right click, and click the "open volume control", click the file at the left top of the dialog box, then go to properties..you must see the title "mixer device", what is your sound type?.."realtek or AC97?...
Feb 20, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Computers & Internet Logo
David Payne
David Payne
