Question about Polyview S17E 17" LCD Flat Panel Monitor
Hi there, I have a Polyview S17E LCD monitor and it looks like I am getting some funny synching/initialisation problems with my graphics cards and the monitor itself. At present everytime I click on the Nvidia control panel (91.28) to open it the screen goes black and then switches on again. Also whenever it goes through a setting change and I click apply....the monitor goes black and then switches on again. When I'm booting up the monitor gets to a point where it switches on, off, on, off 3 times before getting the the windows user select screen as if it can't decide what it needs to do with itself!! i have windows 7 64 bit and in xp its work perfect
5 Suggested Answers
  • 37 Answers
SOURCE: Monitor Display Problem.
The first Polyview has a power supply problem (a short) and locks out the power until it is unplugged. You need to check the voltages inside the Monitor to determine which component/s are faulty. I hope you know electronics if not leave it to the repair shop because you have neither the skills or equipment to repair it. By the way I am not a monitor repair man but I do have 30 plus years in the electronics field.
The second monitor may have a broken wire in the cord that goes to your computer. Other internal components can cause the same simptoms your seeing. Good luck!
Posted on Aug 26, 2008
  • 3 Answers
SOURCE: Polyview V17E
Same as before this sounds very similar to the problem that I had with my polyview v396 19" . Its a power supply problem unclip the panel withdraw the power supply it plugs in on its own seperate board. Look for capacitors that bulge and replace them in fact replace them all on tha board not that hard. Replace them with the same rating voltage and micro fards. Cheaper than relacing the whole panel, hope this helps. :)
Posted on Sep 01, 2008
SOURCE: Grey then screen goes blank on Polyview S17E 17" LCD Flat
Can u solve this problem
Posted on Sep 22, 2008
budmrtn
  • 11361 Answers
SOURCE: Hi. I cant get a Polyview
You need win7 driver which either POLYVIEW or Microsoft has it since it is too old for them to make one, they just want you to buy new monitor, one reason I am still using XP since it works perfectly with XP.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Feb 27, 2011
What does this plug do? I have a polyview Monitor
They are both display cables, DVI (White cable) is digital and the VGA (blue cable) is analog.
If you can use DVI, use it, it's better quality
Comment if you need more assistance
Aug 17, 2011 | Polyview S17E 17" LCD Flat Panel Monitor
Hi. I cant get a Polyview LCD monitor to display at full resolution in win7.
Feb 27, 2011 | Polyview S17E 17" LCD Flat Panel Monitor
The power adapter for this monitor is overheating and the monitor is turning off as a result. Where can I get another power adapter?
The computer store sells universal power supplies that will work with your monitor, and they may even have the exact replacement.
Feb 14, 2011 | Polyview S17E 17" LCD Flat Panel Monitor
I need the power adapter for play view s17e
You can get it here: http://www.lcdpayless.com/productpage.php?productId=6354
or EBAY.
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jan 19, 2011 | Polyview S17E 17" LCD Flat Panel Monitor
Built in speakers
I'd guess there is a jack socket 'audio in' somewhere on the montitor, probably on the back. (Don't confuse it with the headphone socket, which usually looks the same.) Connect it with a 3,5" stereo jack-jack cable to your PC's audio output.
Mar 20, 2009 | Polyview S17E 17" LCD Flat Panel Monitor
Need the polarity of the adapter for polyview v17e moniter
i'm guessing you don't have the original adaptor to test it... sometimes polarity is printed onto the case where the adaptor plugs in... get out your magnafying glass to see it tho.
Jan 02, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview Monitor Black screen
blown capacitors open it up and take a look
Jun 19, 2008 | Polyview S17E 17" LCD Flat Panel Monitor
I have problems with my LCD polyview
These monitors are plug and play compliant and should not require any drivers. If you are having video problems it may be the video card.
Apr 06, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
Basicly dead
blown capacitors on the power or vga board inside
Dec 05, 2007 | Polyview S17E 17" LCD Flat Panel Monitor
Polyview S17E 17" LCD Flat Panel Monitor Logo
42 people viewed this question
Top Polyview Computers & Internet Experts
David Payne
David Payne
Are you a Polyview Computer and Internet Expert? Answer questions, earn points and help others
