Question about Watches
How to set time on tru time watch - Watches
How to set digital part of the watch
[PDF]4 Button Digital Watch - Dakota Watch
https://www.dakotawatch.com/PDF_FILES/Digital.pdf
In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.
how to set time in digital watch - YouTube
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
How To Change The Time On Most Digital Watches - YouTube
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Jan 05, 2016 | Watches
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
Tru time atomic talking watch instructions
I own a independent watch (no name) I recieve as a gift. The only hint is on the face.is "TRUE TIME" and "Talking Watch". I enjoy tinkering with technology and so enjoy the watch. However it always says "USA time not updated", though the time is fine. So I found instruction. This site is concise and so might help others as well:
http://www.independentliving.com/instructions/756504.doc
Sep 09, 2013 | Watches
Hello, how i can set a time on addidas candy watch. it's late on one hour, we did try ev erything, but they still late. thank you
Thank you for contacting FixYa.
  1. Press the top button on the right-hand side of the watch to view time.
  2. Press the bottom button on the right-hand side of the watch and hold for two seconds.
  3. Press the top button on the right-hand side of the watch to choose a 12-hour setting or 24-hour setting. Stop when the desired format appears.
  4. Press the bottom button to change to time set mode.
  5. Press the top button until the desired time appears. Press the bottom button to exit time setting mode. The watch is now set.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Best regards. Jewel
Sep 09, 2010 | Adidas Candy Digital watch
I accidentaly reset time & date on my square arnette watch and i need help to set it
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 | Watches
Turn off alarm and how to set alarm
After a bit of searching I found a makers name for you. I trust that this is the make you have (I doubt if there is more than one!)
If you go to "www.accessible-devices.com/reizen.html", this is an instruction sheet for Reizen talking watches.
Jan 20, 2010 | Watches
Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
May 14, 2009 | Diesel Digital Dz7069 watch
Can't set the time on my casio wrist watch
Press button A (top left) and hold for two seconds. The watch should then receive a time signal - you shouldn't have to set the time on it at all.
Mar 08, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I cannot set the digital time on diesel watch DZ7101
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT DON'T FORGET TO RATE
Jan 11, 2009 | Diesel Watch DZ7071
Watches Logo
190 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
