Question about Garden
Need a new blade for the champion PDCPLM4235F. Any ideas where I can get one from?
Overheating champion juicer
to the person. champion juicer running hot. if your blade is dull it will run hot bcuz its harder to turn and gets clogged easy. look online for new or less used blade.
Jun 13, 2014 | Champion G5NG853S Household Juice...
Pulp is building up, not ejecting properly
When juicing with the champion juicer take it slow. You need to hold down the tamper for three to five seconds in-between reloading the chute. Otherwise it will begin to back up through the chute and the juicer will begin to heat up. Happy juicing! LivingaHealthyandHappyLife.com
Mar 07, 2012 | Champion G5NG853S 540 Watts Juicer
I installed a new hub on a Champion Juicer, reconnecting the wires that are attached to the magnet; when I turned it on there were lots of sparks. Any ideas to what could be wrong?
I have had good experience with their technical support.
Corporate Headquarters:
PLASTAKET MFG. CO., INC. / Champion Juicer
6220 E. Highway 12
Lodi CA, 95240
USA
Tel: 866-935-8423 / 209-369-2154
Fax: Fax Number
E-mail Contacts:
Business Relations - sales@championjuicer.com
Wholesale Inquiries - doug@championjuicer.com
Nov 17, 2011 | Champion G5NG853S Household Juice...
Have a champion gun safe. Moved it to a new location. Now it won't open. Any ideas?
If your model safe has the glass relocker and you didn't re-pin the relocker when you moved it, you might have broken the glass relocker during the move. That would keep it from opening.
Jun 21, 2011 | Champion Scuba Diving & Snorkeling
CHAMPION PAPER SHREDDER
My champion shredder had too many papers go thru because I didn't see the enclosure in one of the flyers. the shredder has now stopped. I have tried to pull the paper out but I reverse the wheel and now the paper is stuck behind the the wheel where I can reach. The motor is now ona humming sound. Are there screws on either end that I can remove the top? Please give advise n what to do. This is not and old shredder.
Oct 20, 2008 | Office Equipment & Supplies
Juicer heating and pulp is wrapping around blades
Parts from Champion website. You may need a new cutter, sometimes cheaper on ebay.
Jun 22, 2008 | Champion 2000+ Household Juice Extractor
My Champion Shredder doesn't cut off after the paper goes through.
Mine now just has the same problem. On mine it was because two of the cutting blades have become bent. It still shreds, but not as fast. You have to turn it on for a split second to see all the blades. You can only see about 1/4 of the blades at a time.
There is nothing you can do. And because my blades are bent it does't dispose of paper properly and also will not turn off automatically now.
Apr 07, 2008 | Office Equipment & Supplies
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
