Question about Moen 3867 Four Function Hand Shower With Slide Bar
I have a 4 function Moen hand held shower head. We've had the shower head approximately 4 years. There is water leaking out the back of the adjustable ring in the shower head reducing pressure to the head. Can this be repaired?
4 Suggested Answers
  • 81 Answers
SOURCE: Moen Hand Shower repair
I don't ever remember seeing a parts breakdown for any Moen hand held shower head. They are like light bulbs and when they go out they are done. Try calling 1-800-BUY-MOEN (1-800-289-6636) for the definitive answer.
Posted on May 29, 2010
  • 82 Answers
SOURCE: Moen model 3867 has a
recheck all the washers and try a little teflon tape if necessary
Posted on Dec 09, 2010
  2. start unthreading centre of head. I used a paint scraper to leverage at first. The threads get loose soon to hand loosen.0588438c-31ce-4428-9378-28140fa37adb.jpg
  3. loosen the spray ring using a lever to get threads started. Hand loosen after that.It's got right hand thread so the outer ring will be turning counter clockwise.3e2cc1ab-35f5-4521-a05f-e1167596fb04.jpg
  4. Take flat rubber gasket out of centre of head and take screw out, then pry white nylon part out with tool. I used tweezer.a1f4f121-e0e1-450a-a9b8-8777342a3262.jpg
  5. Clean scraped parts in hot CLR solution or any vinegar will work as well. Reassemble with lubricant so it works like new. Most likely need for disassembly is clogging or a broken "o"-ring.6fff7106-1b7b-4330-a3c6-089ea42233cf.jpg
Posted on Jun 02, 2013
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
Almost zero water pressure or hot water from our hand-held Moen shower head model # 3827 CP. Our regular head next to it works fine. Suggestions as to what the problem or solution might be?
Remove the head from the hose and test. If water flow is adequate through the hose, the problem is in the head. Look inside the head where the hose connects for a restriction, perhaps twisted rubber. If the issue might be with clogged jets, try soaking in CLR to remove built up deposits.
Hope this helps, --W/D--
Jan 24, 2011 | Moen Plumbing
I have extremely low pressure from my Moen Posi-Temp 1222 shower valve, but otherwise it functions well. Should I replace the posi-temp cartrige?
Hi Ken--
Positemp cartdiges should deliver years of maintenance free operation. Usually, clogs develope downstream from the cartridge. If the cartridge still works well, that is, if it still pulls and turns freely, and the rest of the house has decent water pressure, check your shower head. Remove the head and test the water pressure. If the water flows better without it, you may have a clogged shower head. Over time, rust and scale can build up inside the shower head and block what would otherwise be decent water pressure. If a visual inspection does not yield any visible blockage, you can consider cleaning the head by soaking it in a calcium removing solution such as CLR. This often helps, but my preference is to replace the shower head completely.
--Hope this helps.
Oct 06, 2010 | Moen Plumbing
Water Pik Elements Hand Held leaking at flow adjustment
Shower heads, by and large, are not built to be serviced. There are generally no parts available for even the most expensive head. Consider it a light bulb...when it dies it's dead and there is no rebuild
May 23, 2010 | Water Pik & Wallmount Showerhead
Apr 13, 2010 | Moen 3867 Four Function Hand Shower With...
Just installed a Moen 3867 hand held shower. There is no water coming out of the head. Water flows just fine from the hose without the head attached. Is there a restrictor plate or something I can...
Usually whenever you do any repairs on plumbing, you dislodge calcium from the inner surfaces of teh plumbing. Check to see if ther is a mesh filter in the inlet side of the head. and remove and clean it. otherwise you could remove it and use a vacuum yo try and remove any deposit that may be in it. If that is unsuccessful,
you can always return it, but always remember to open the fawcett and run it before installing the head.
This is an essential part of any plumbing job. Good luck
. If your local store refuse to replace it Moen will gladly do so with no problem.
They are good like that.
Mar 04, 2010 | Moen 3867 Four Function Hand Shower With...
Moen shower head leak
Single handle shower controls always have some water trapped inside. It has probably freeze damaged the cartridge
Apr 29, 2009 | Moen & One Handle Tub & Shower Faucet
Our shower has not been used for a while. Now when we turn it on
Do you have good flow if you remove the shower head, y/n if not how old is house,galvinized plumbing?? or copper plumbing. Sounds like you have a clogged valve and if so this link will be good.
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Apr 02, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3867 Four Function Hand Shower With Slide Bar  Logo
97 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
