Question about LG LRBN20510WW Bottom Freezer Refrigerator
I have a LG refrigerator, freezer on the bottom, about 10 months old. it has started making a grinding sound that sounds like a motor running down, then it stops. this is happening a couple of times an hour. i am not using the ice maker. this happened once before and then stopped. i don't know how to fix it and the sound is annoying as hell! please help (everything else on it works fine). also no water dispenser on this unit . this is a stainless unit, not sure the product info is accurate
  • thecalmthelo Mar 13, 2011
    guess what! i never noticed this before, but i actually have visible ice build up on that area without even removing the cover! is this s serious problem--do i need to call for service? thank you!
    also, i cannot figure out how to reach that cover and remove the top shelf. i have knocked the ice off the back, but the sound is continuing.
  • 4,059 Answers
Tale cover off the rear of the inside of the freezer and see if you have ice build up hitting the fan. This would indicate a defrost problem.
Posted on Mar 13, 2011
  • 1 more comment
  • Charles T Nevin
    Charles T Nevin Mar 14, 2011
    There should be screws on each edge holding the panel in.
  • thecalmthelo Mar 14, 2011
    yes. i can't reach them b/c of the shelf. if i can see the ice, is this a problem that requires a service call? i can see the ice on the wall itself, w/o removing the panel. thank you.
  • Charles T Nevin
    The coil which is iced up is behind the panel and the heater and thermostat are also there. If you want to try fixing it yourself you probably can. There seems to be a problem with this site because I don't seem to be able to post the directions for your. Try a search for defrost problem.
Whirlpool gold French doors freezer in the bottom it's making a knocking or rattling sound like it's coming from the back panel in freezer open freezer it stops close it starts
SOUNDS LIKE YOUR FAN MOTOR IS EITHER LOOSE OR THE MOTOR IS ABOUT TO GO OUT(NOISE INSIDE COULD BE GEAR IN MOTOR GRINDING WHILE WORKING) it stops when you open the door which shuts off he fan motor to help prevent loos of refrigerated air.
Dec 04, 2016 | Whirlpool Refrigerators
The refrigerator make noise. It seem to be from the motor. It is only 1 year old.
I think that sound come of the fan in the freezer. This sound is intermittant. It's possible that problem is cause by a defect bearing?
May 19, 2010 | LG LRDC22744 Bottom Freezer Refrigerator
I have a 1976 model Sears Coldspot that is making a girgling/grinding sound from the freezer area. I remove the fan cover plate and the fan was rotating ok but every so often it would hesitate and slow...
if the temp has risen,check and make sure its not stuck in defrost mode,if it is advance the defrost timer ahead so the compressor again starts and runs,the only other thing would be the motor that you said is slowing down is getting noisy bearings and make that grinding sound,the gurgling noise could be just freon/refrigerant moving through the evaporator coils in the freezer
May 14, 2010 | Refrigerators
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
My Samsung RF266ABRS makes a sound like ice falling into a bucket
Check with the people you bought it from. There should be a warranty.
Jun 26, 2017 | Samsung Refrigerators
Loud compressor noise from lg frig...
The sound you hear is the Freezer Fan, this problem is hard to diagnose, because the fan spins but not fast enough to circulate chilled air thru the freezer and refrigerator. The minimum labor and material cost for the repair/replacement is around $300.00. But if you chose to make the repair yourself the motor alone costs around $80.00@appliancefactoryparts.com. But the repair is very labor because the electrical connection for this fan is at the rear of the unit
Jul 30, 2009 | LG LRSC26940ST 36" Side-by-Side...
Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Jun 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
LG LRBN20510WW Bottom Freezer Refrigerator Logo
128 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
