Question about Adidas Candy Digital watch
How do change/set time Thank you - Adidas Candy Digital watch
How do I set the time and date on my 1440
hi,
You can try this by:
Press and hold the "MODE" button (top left) until the alarm time begins to blink. Use top right button to change from minute to hour etc, and change the value for the setting that is flashing by pressing the bottom right button "SET". Change from alarm to date to time by pressing the upper left button again.
Hope this will help you.
Thank you for choosing fixya
Feb 27, 2011 | Timex 1440 Nylon watch
How do change the date on my citizen divers watch
Hope this will helped you fixing the time of your Citezen divers watch. Just foolow the instruction below.
Change your Citizen watch's time zone without actually moving the clock hands. On the digital display, change the city that displays on the watch, which sets the time to the different time zone. The Citizen also has a calendar, timer, chronograph and LED lights. Since it is an Eco Drive watch, it is solar powered so you never have to replace the batteries unless its backup power source dies.
Difficulty: Easy Instructions
  1. Pull the setting knob (crown) out one "tick" for setting mode.
  2. Set the mode hand to "WT-S."
  3. Pull the crown out one more "tick."
  4. Press the top button on the right side of the watch for the city setting mode.
  5. Press the lower button on the right side to "SET" the city.
  6. Turn the crown to select a different city, which changes the time zone.
  7. Push the crown all the way back in to finish setting the time.
Thank you for using Fixya.
Feb 21, 2011 | Citizen Watches
I need set the date of my Armitron watch Thank you
Hi diazlieter,
To set the date of your Armitron watch, please do the following.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Feb 14, 2011 | Armitron 40/8125BLK Digital Sport Watch
Can not set the time 1 hour ahead and will not change help Example the time is 11:56 the watch displays 12:56 how do i change the time?
Hi rsingl4069,
You can easily set the time of your Armitron watch by following the steps below.
Hope it helps.
Dec 28, 2010 | Armitron 40/8125BLK Digital Sport Watch
Hello, how i can set a time on addidas candy watch. it's late on one hour, we did try ev erything, but they still late. thank you
Thank you for contacting FixYa.
  1. Press the top button on the right-hand side of the watch to view time.
  2. Press the bottom button on the right-hand side of the watch and hold for two seconds.
  3. Press the top button on the right-hand side of the watch to choose a 12-hour setting or 24-hour setting. Stop when the desired format appears.
  4. Press the bottom button to change to time set mode.
  5. Press the top button until the desired time appears. Press the bottom button to exit time setting mode. The watch is now set.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Best regards. Jewel
Sep 09, 2010 | Adidas Candy Digital watch
CAN YOU EASILY EXPLAIN HOW TO SET ME TIMES 1440 SPORTS WATCH. SINCE TIME CHANGED WE ARE UNABLE TO SET AND CANNOT FIND INSTRUCTIONS THANK YOU
Hi garysuzie,
To set the digital time and date on your Timex, please follow the steps below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Nov 03, 2009 | Timex 1440 Nylon watch
I would need to set the time on my timex WR50M watch and I have missed place my instruction sheet. I would need th instructions Thank You
Hi fuscoromeo,
Timex Digital Watch
Hope it helps.
Nov 02, 2009 | Timex 1440 Nylon watch
Change from miliary time
Please follow the procedure below.
Hope it helps.
Oct 02, 2009 | Timex 1440 Nylon watch
Acqua Indiglo watch
Can't understand instructions
Aug 31, 2008 | Watches
How to change the time Trying to set the hands on the watch
good morning ! you need to full the crown first after that wind it to change the time after set the time push back the crown,thank you ! god bless !
Aug 27, 2008 | Casio Casual Sports Watch HDC6007BVCF
Adidas Candy Digital  watch Logo
665 people viewed this question
Top Adidas Watches Experts
Ansel Alberto
Ansel Alberto
Geoff
Are you an Adidas Watch Expert? Answer questions, earn points and help others
