Question about Maytag Washing Machines
Washer keeps getting off balance even when clothes are balanced inside.
  • Czerney Dort Mar 13, 2011
    Is it a maytag performa? If so then it is made by crosley I put a post on here a while back to tell a person what there problem would be . Would need mod number to know if it is a real maytag if it is a real maytag the tub springs are adjustable easy way to tell if it is a real maytag is to look at bootom of machine if it has 2 belts it is a maytag.If it has 1 belt it is a crosley built machine.. find that out and you can get back to me i will tell you what to do ..Good luck
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 13, 2011
My GE washer GTW460NMKwww, the drum will not balance itself when going into final spine cycle.
Are the clothes evenly distributed inside the drum and the washer not overloaded? The drum is not self balancing, you must take care when loading it to even the weight distribution
Mar 01, 2017 | GE Washing Machines
What is the name of the parts that keep a the wash tub centered and balanced and can they break? whirlpool washer LSN1000HQ0
Here's a start.
Type in 'Sears parts direct" on your computer.
Then, type in your model number.
You will get pictures of your machine, every part there is.
Perhaps you can figure which part you will need.
God bless your efforts.
Oct 13, 2015 | Whirlpool Washing Machines
Spin with loud noise and shaking
The clothes inside the washing machine are not balanced. Too much weight on one side. Try to move some clothes to the other side to balance the weight. It may take more than one time of moving clothes to get it balanced correctly.
Aug 01, 2015 | Samsung WA400PJHDWR Top Load Washers
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Spinning is out of balance even when there are no clothes in the washer
Most has a balance ring built onto to the tub, make sure thr balance ring is not damaged, It is normal for the tub to shake in the spin cycle with nothing in washer
Dec 22, 2009 | Kenmore 22422 Top Load Washer
Washer off balance
what I did was just grab the part that cleans the clothes and gave it a good shake and rock. Then I balanced the washer on the feet, you will see four small circles on the botttom that can be turned to get it balanced. Level it to make sure the washer is even on all sides. If you washer walks out when you wash clothes like mine does, get a non slip mat and put it underneath the washer or something in all four corners.
Oct 13, 2009 | Kenmore 24032\24036 Top Load Washer
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
WF865 noise when spinning
Washers have to be balanced. Some have balance adjusters either inside the dryer as explianed above or on the bottom to level the washer. try to balance it by turning the bolts slightly or the bottom portion of the washer to level it. Or else they want to shake apart. Also by distributing the clothes evenly so it won';t be all to one side can help. do not tighten the screws all the way. Just tighten them to the point of getting the right balance.
Jun 16, 2008 | Hotpoint Ultima WF865 Front Load Washer
Washer
There are only springs that balance the machine. An even amount of clothes inside the washer keeps it balanced. But on the ropers the tub is designed to be very loose like it is. Load the machine evenly and you should be fine.
Apr 26, 2008 | Roper RAS8445KQ Top Load Washer
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Jun 30, 2006 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
