Its flashing f28 and lock i have something in the washer also this is only my secind time using it i unpluged it and its still doin it
  • razalx Mar 25, 2011
    whirlpool ADG699 dishwasher.
    I'm:
    1. trying to start a program (select the program and it's options) and press Start button and afterwards close the cover
    OR
    2. simply press ON button and afterwards close the cover
    RESULT:
    dishwasher starts to beep (2 times), the led to blink (2 times) and to make a sound and in about 60 secondas stops (the sound stops - and continues beeping and blinking). Opening the cover i can see the F2 message.
    What can I do to make it start? What does the message means?
    Thanks in advance.
  • 3 Answers
I have been chasing this issue for several months. I am on my third Computer (CCU). I buy a new computer and it only lasts a month. This latest coputer only lasted a week.
An interesting thing occured to me, every time I played with the wiring on the washer, it would work for two or three loads, then my F-28 error would come back.
F-28 is a communication error. There are two computers in the washer. Central Computer and motor controller computer. There is a serial bus between them (3 wire connector on the top of the CCU with a blue stripe). From my research, I discovered that these washers have a corrosion problem. The data communication wires are susceptable to this.
One thing I noticed was that my washer seems to always quit when starting the spin cycle when the washer is really shaking.
Here's the solution:
Find that 3 wire connector and clean the contacts on both sides of the wire harness (CCU and MCU sides). This can be accomplished by running some light sandpaper between the contacts. You should also do this to the wires going to the motor sensor on the back of the motor. This solved my problem. I figure I will probably need to go in and repeat this every year or so.
I also found this awesome troubleshooting guide. It has A LOT of great information
http://www.slashdocs.com/mypwxs/8178686-maytag-epic-z-front-loading-washer-technical-education.html
Posted on Aug 02, 2013
    Scholar:
  • 158 Answers
If your washer is a Kenmore The F28 error code on this model of washer indicates a communication error between the motor control unit and the computer circuit unit that results in the washer stopping during a cycle.
Read more: How to Unlock a Kenmore Washer HE2 Code F28 ' eHow.com http://www.ehow.com/how_7727221_unlock-washer-he2-code-f28.html#ixzz1GUHtruhM
Posted on Mar 13, 2011
HE2T front load washer F28 flashes machine is locked clothes inside cannot open help
tre
ert
Sorry to read about your problem, I hope this helps you out.
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for
error code F28
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Jan 03, 2011 | Kenmore HE2 Plus Front Load Washer
My washer say f28 it is a kenmore HE2 plus
"F28" means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.Reach up near the latching assembly & attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thank you!!
Jul 18, 2010 | Kenmore HE2 Plus Front Load Washer
F28 code
Thank you!!
Jul 05, 2010 | Kenmore HE2 Plus Front Load Washer
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
You can download the online repair manual in the below link
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
On page# 4-20 it shows how to access your MCU.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does trouble code f28 mean
f-28 was flashing on my washer for the longest time, first i had read that my heating element had gone out which was false, my washer still produced the steam and heat prior to error code f-28 then shutting down.The 2nd thing i read was F-28 meant the locking switch on the door was going bad which again was false, my washer would lock and unlock allowing me to feed more clothes. So i took it upon myself to remove the lower cover clean and was my RINSE filter which at that time I discovered the DRAIN tube was pushed against my wall not allowing enough water to flow out on my washers RINSE & SPIN cycle.
If you have this problem I would recommend following your service guide to trouble shoot the RINSE FILTER & DRAIN PIPE. The washer motor spins so fast that the washer itself need to drain the water out 10X's faster then a regular standard washer!
Hope this helps cause it did for me and saved my wife and I alot of money in repairs!
Mar 31, 2010 | Kenmore HE2 Plus Front Load Washer
It gives a F28 code. What is that?
F28 is a motor controller error... Try unplugging the machine for a minute or two, then starting it again. If no good, you can remove the access cover and check the connections to the motor... BE SURE TO UNPLUG FROM WALL FIRST...
Peace,
Mar 30, 2010 | Kenmore Elite 45986 Front Load Washer
ERROR CODE F28
Unplug the machine at the mains. Remove the detergent tray. Reach all the way back with your hand in the slot where the detergent tray normally fits and feel for a lever. When you find it pull it forward. Then replace the detergent tray. Plug the machine back on and the error code will have reset and the machine will be useable again.
Oct 05, 2009 | Whirlpool Washing Machines
F-28 code
F28 means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.
Reach up near the latching assembly & Attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 28, 2009 | Kenmore HE2 Plus Front Load Washer
5E Washer - Won't Fill / F28 Error
check if hoses are reverse when installed
May 12, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
2,006 people viewed this question
Top Washing Machines Experts
