Question about LG Televison & Video
I have a brand new straight from box LG TV model 32LD320. I have unpluged the HDMI from old TV ( where was working 100% OK) plugged into new TV. Mains switch on - and cannot get any chanels to report on AUTOSETUP Manual setup goes to Channel 21 and stops. No repsonse on remote or switches at side of new unit. Changed batteries on remote. No change. Still cannot get past setup.
    Scholar:
  • 146 Answers
HDMI sends video from a source likea bluray player or 'cable box' to tv it will not send signal so you can program channels from it
turn tv to the HDMI input you plugged device into and watch cideo from that source
you will need to connect some type of antenna to be able to program channels on tv
very few tvs need channels programmed these days since most people hook up a cable or sattelite receiver and change channels that way
hope this helps if not give me more speecific details and i can help you more
good luck
Posted on Mar 13, 2011
How to repair lcd panel tv of lg 32inch
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in the "Brand Name" (Exclude the model number) to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 07, 2016 | LG 32LD320 32 HDTVReady LCD TV
How do I connect a virgin v box to an old lg model?
The hdmi cable would not be compatible with your old style TV, if the Virgin box has a scart socket then that is your best option!
Nov 07, 2014 | LG Televison & Video
LG 32LD320-ZA remote sensor
Replace the remote sensor. this component can be located just behind the infrared window at the front panel.
Jun 13, 2012 | LG 32LD320 32 HDTVReady LCD TV
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
I have an old Yamaha RX-V793. It works perfectly fine. Now I have a new LCD screen, a new DVD player and my new cable tv set top box. All 3 take and use HDMI. I'd like to be able to HEAR BOTH my DVD...
hi,
u can make connections only through digital inputs(optical and coaxial). u can connect the digital outputs of ur dvd and cable set top box to the receiver. no way to connect HDMI. HDMI is a high definition media interface. for using it u have to go for a av receiver that supports HDMI.
ok
Dec 23, 2010 | Yamaha RX-V793
Manual for LG TV 32LD320
The manual is available as a PDF at the LG site: http://www.lg.com/uk/tv-audio-video/televisions/LG-lcd-tv-32LD320.jsp . Click on Support and then find the link for the User's Manual on the right hand side of the page.
I hope this helps.
(javascript needs to be enabled for the site to work; it works well with Firefox.)
Nov 17, 2010 | Televison & Video
YOUR TV DOES NOT ALLOW DISPLAY OF THIS PROGRAM THROUGH THE DVI IN
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Sep 18, 2009 | Toshiba D-R5 DVD Recorder
Sony connectivity
OK, here are info...
first unplug TV and dvd recorder from AC outlet and put hdmi cable as follows...
at rear side of TV, you have 2 hdmi inputs, hook hdmi cable in any one of them and other end of hdmi cable will be hooked in hdmi out of dvd recorder rear side.
Now, plug both units in AC outlet and power up, go to TV menu > hdmi setup > and perform device list update.
TV will recognize dvd recorder and you will see dvd recorder logo screen.
Let me know if you need further info / help.
Dec 23, 2008 | Televison & Video
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Lg 50inch tv(lg50px4d-eb
I've been finding quite a few HDMI related problems over the past year and it seems to be increasing. The problem usually is due to the cable being somewhat heavy. The plug sticks straight in and hangs. The weight of the cable uses the downward momentum and starts ripping the solder connections from the televisions HDMI input. When the audio becomes distorted, try moving the cable and see if it clears up. If it does, then, that's the problem. If not, then the problem is more than likely the audio circuit. Either way the Main PCB needs to be replaced. After replacing the Main board, I suggest using component inputs instead (Same quality picture, just more cords), because, the chances of another problem caused by HDMI is likely. Hope this helps.
Apr 08, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
270 people viewed this question
Computer Repairing
Computer Repairing
