Question about Toshiba Televison & Video
While watching on my toshiba 32av700, the channel jumps to 0 without being prompted to do so. :-( our tv viewing keeps getting interrupted by this occurrence.
    Scholar:
  • 146 Answers
Either a button is stuck on your remote or you are getting too much sunlight directly on your tv
try removing batteries from remote and see if that stops problem - if so that is problem - if not then try covering the spot on tv that is the remote receiver and see if that stops it
let me know if you need more help and give me more details and i will try to help more
Good luck
Posted on Mar 13, 2011
My toshiba keeps jumping between source channels- any ideas
Not sure, but sounds like the problem is with the RC. Try watching TV without the RC to see if it stop jumping between channels.
Jul 10, 2016 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Tip
Toshiba 50HP95 Channel Block Reset
Toshiba 50HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 50HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Tip
Toshiba 42HP95 Channel Block Reset
Toshiba 42HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV channel block?
I hope that helps.
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Toshiba 42HP95 Television
Do I need cable to view local news
Yes it is called "DTV" digital television, you will need a tv, the tv must have a digital tuner built in most do now a days, if your tv is older you will need a digital converter box also, you can go down to your local store to find a digital antenna- take it home and try it. the issue with this is you can get all channels perfectly in one room with no problem and in the next room with the same exact equipment you wont get any or very little channels, unlike traditional analog television digital television either works or not, no sketchy picture- best advice is to buy a set up from a store that allows returns and try it, if it don't work try a different antenna, also try moving it around, keep in mind you will interfere with the signal so if it works take a seat in you chair it might interrupt the signal--Good Luck.
Mar 30, 2013 | Philips 37PFL5332D 37 in. LCD Television
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
Channel Changing
Some TV's have a 115 to 125 channel limit then will go to video in and then channel 2 and start over. Your TV's tuner may not have the ability to decode those channels. My suggestion would be to get a set top box (cable box) that can access channels. Your provider should have these or can suggest where to get one. Probably less expensive than a new TV.
Sep 24, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba 51H83 51 in. Rear Projection pisture issue
I have a wild guess. I have the same tv and channel 72 is the proper channel to watch tv on. I don't know why, but maybe try channel 72 instead of the usual channel 3. Good luck, maybe a quick fix, maybe not!
May 30, 2007 | Toshiba 51H83 51" Rear Projection...
Channel jumping
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Apr 10, 2007 | Sony KV-36XBR450 36" TV
Televison & Video Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
