Question about Cycling
I want to raise the headset - Cycling
    Sergeant:
    Champion:
  • 263 Answers
Clarify your question
Posted on Mar 13, 2011
I want to raise my handdel bars highter.
  1. Loosen the headset bolt located on top of the stem.
  2. Raise handlebars to desired height.
  3. Re-tighten the headset bolt.
Sep 03, 2015 | Cycling
Adjust handlebars
you can't raise the stem on a Aheadset type stem/headset, they are not designed for it from the manufacturer.
Apr 17, 2014 | Diamondback Grind 20 Boys' Freestyle BMX...
T5 classic mudguard how to change one
Disconnect brake cable.
Remove handlebar headset top screws x 4.
Push speedo cable into fork leg to raise headset top.
Disconnect speedo cable and wiring plug.
Remove handlebar clamp bolt and pull handlebars up to remove and hang on cables.
Remove locking nuts and washers from top of steering column.
Get help to raise front end of scooter and forks will slide out. (Suggest doing this bit over sheets of newspaper to catch any loose bearings.)
Remove the three bolts holding mudguard to fork and slide up the column.
Do the above in reverse to refit.
Dec 20, 2013 | Peg Perego Vespa Scooter
No sound coming from the phone. only headset works.
Try unplugging your headset, or raising your volume.
Feb 17, 2013 | Philips Computers & Internet
Peltor MT53H7AWS2 Bluetooth Headset pairing instructions
• Establish the Bluetooth link between the headset and another Bluetooth device by pressing the raise volume (+) and lower volume (-) buttons simultaneously for at least two seconds. Note that the headset must be switched off while you do this!
Some models of mobile phone require a pin
code in order for the mobile phone to identify the
headset. If this is required, enter four zeroes (0000).
This applies to all Peltor WS headsets and cannot be
changed by the user.
Nov 07, 2012 | Peltor MT53H7AWS2 Bluetooth Headset
Headset picks up but there's no dial tone and we can't dial out.
The CS70 headset is definitely paired up to the base and has a good connection if the lifter raises up, sounds like maybe the compatibility setting may need adjusting. The number one should be in the three O'clock position, the compatibility setting is on the left side of the base unit. Here is a link below for the user guide if you need help with the adjustment.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
Jul 05, 2011 | Plantronics CS70 Wireless Headset
Iw ould like to raise the handle bars on my wifes bike-how do I adjust
Most likely you have a threaded headset on your wifes bikes. Many times you will have to replace some of the cables and housing because they will be too short once the handlesbars are raised.
If you have a treadless headset than raising your handlebars is very simple. First check to see what type of headset you have. A threadless system with have a allen head on the very top of the stem and one or two more allen head bolts on the side of the stem. The threaded system will usually have only one bolt on the very top of the stem. It is sometimes covered by some type of cap. Also on threaded headsets, there will be a large nut under the stem, which is what most people mistakenly loosen to adjust the stem. Do not touch this nut, it will adjust the headset. Same goes for the allen head on the treadless headset, it will also adjust the headset so don't touch it.
So if you have a threaded stem, simply loosen the allen head or nut on the top of the stem and raise the stem up. Make sure you do not go above the max line and that you are still able to turn the handlebars freely.
Hope this helps!
Jul 12, 2009 | Huffy 26in Ladies Sante Fe Cruiser Bike -...
Can I raise the handlebars on my Marin hybrid bike and how do I do it?
Most likely you have a threadless headset on your Marin which means you can not raise the handlebars without replacing the stem or handlebars themselves. In addition, many times you will also have to replace some of the cables and housing because they will be too short once the handlesbars are raised.
If you do not have a treadless headset than raising your handlebars is very simple. First check to see what type of headset you have. A threadless system with have a allen head on the very top of the stem and one or two more allen head bolts on the side of the stem. The threaded system will usually have only one bolt on the very top of the stem. It is sometimes covered by some type of cap. Also on threaded headsets, there will be a large nut under the stem, which is what most people mistakenly loosen to adjust the stem. Do not touch this nut, it will adjust the headset. Same goes for the allen head on the treadless headset, it will also adjust the headset so don't touch it.
Hope this helps. If you need any more help you can connect me at elijah@starbikesfl.com. Thank you
Jun 27, 2009 | Cycling
How do I raise the volume on the Motorola Bluetooth H670?
simple raise the volume on the phone the blue tooth is paired and will go up automaticly
Apr 13, 2009 | Motorola Mobility Bluetooth Hands Free...
Dont know how to turn the volume up on this headset
turn your headset off. when you turn on yourheadset back on , push the volume you wish to control the volume with. this buttom you choose shound be your volume up button now.
Aug 31, 2007 | Motorola Mobility H350 Wireless Headset
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
