Question about Fisher and Paykel Washing Machines
Top load washer - no power - power is to outlet, unplug for half an hour replug no change, board does not light up, remove clothes and water, no change - next step?
    Brigadier General:
  • 6,277 Answers
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 13, 2011
Lg front loader washing machine has no power
You will need to unplug the washer, remove the 4 screws from the white plastic pieces on the rear of the machine main top, remove the top by sliding to the rear, locate your main computer board in the top left, plug the washer into the wall, check for a small red LED light glowing on the board. You may have to unplug the washer again and remove the cover in front of the computer board to be able to see the light. If there is no red light your main control board is out, but this could have been caused by another failure such as a faulty stator, or rotor on the motor. Sometimes the connecting wiring from the front control panel to the main rear board will become loose and suffer damage against the moving tub. Best to have a qualified repair company check things out. Pleazer Appliance...
Apr 14, 2014 | LG WM-2277HW Front Load Washer
Kenmore High Efficiency top load washer hung in rinse cycle
What is the complete model number of your unit?
Dec 09, 2012 | Washing Machines
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
I was going to wash a load of towels and the washer filled up but I realized it wasn't enough water in it so before I could set the dial for more water, it stopped filling up so I set the dial for more...
Look around at outlets that are close by and make sure you didn't trip one of your GFCI breakers or plug in something to the same outlet and make sure you have power at the outlet where the washer is plugged into.
May 30, 2017 | Maytag Legacy Series Top Load Washer
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Washer door will not open. Power button will not
You can manually unlock the door on this washer. First you should unplug the washer from the wall outlet and then remove the lower access panel. With the lower access panel removed, and the washer unplugged, reach up to the door lock and feel for a round release ring and pull it down. The door should unlock now.
Thank you !!
Jun 30, 2010 | General Electric WCVH6800J Front Load...
Kenmore eilite oasis
UL stands for an unbalance load where one side the tub is heavier than the other side.
when the code is displayed, it automatically unlocks the lid so you can go in and reposition the clothes to try and balance it. once you are done, simply press the start button again and it should continue again where it left off. if you push the stop button, it will drain the water and assume the cycle is complete.
unplugging it and replugging it in should allow you to do other wash cycles. press power and you should be able to select wash cycles.
if you still have no control, make sure you still have power at the outlet by plugging in a lamp and turning it on. if no power, find the GFI outlet that controls that outlet and reset it. if not on a GFI outlet, then check the circuit breaker panel for a popped breaker. reset it and power should now be restored.
Mar 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis he 580 washer will not power up, I unplugged,
I have had the same thing happen. I unplugged it for a day and when I replugged it in, no spark and the machine worked again. I figure there is an internal over-voltage that get tripped by a faulty component. I frankly think it is just a bad electronic design, but I am investigating.
Jan 25, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Calypso Problems
Make sure the outlet has power, if it does then you have a control board issue or possible wiring problem inspect/test control board input voltages
Sep 26, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
WASHER will not respond or Turn ON
Lg wash machine do not normally have fuses. 90%chance the board is blown. Trace the power to the board. if there is power, boarb is faulty. there should always be am indicating light of a sort when power is applied even if you had other problems.
Apr 09, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
