How to take off processor - Computers & Internet
  • 79 Answers
Hi
may i know why do u want to take the processor off.
Ok, u fist hav to tell me the model and the manufacturer name.
becoz diff manuacturers hav diff settings.
Posted on Aug 01, 2008
Mx6955 processor support
Compatible Processors Pentium 4, Celeron D, Pentium Extreme Edition, Pentium D 64-bit Processors Compatibility Yes Processor Socket LGA775 Socket
Aug 11, 2013 | ASUS Computers & Internet
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
What would cause my aspire 5630 to shut down sporadically?
Shut down sporadically, caused by rising temperatures on the processor (processor overheat). Processor overheat, caused by damage to the processor fan. Processor fan function to reduce the processor temperature.
Possibilities and solutions
1. The possibility of sluggish processor fan. Processor fan spins, with a low speed, so it can not reduce the processor temperature.
Solution: clean the processor fan with a vacuum cleaner, or replace the processor fan.
2. The possibility of fan processor die.
Solution: replace the processor fan.
The characteristics of damage to the processor fan
After the laptop is turned off (more than 1 hour), the laptop can turn on and survive + - 30 minutes. In the period of + - 30 minutes, the laptop died suddenly, because the processor temperature exceeds safe limits (shut down temperature).
How to check
Laptop is turned off (more than 1 hour), then turn on. Download and install software to check the processor temperature. Ex. Real Temp 3.60. See the change in temperature. If the temperature continues to rise, it can certainly cause damage to the processor fan.
- Normal temperature, when first turned on + - 38oC
- Normal temperature, after turn on for hours 40oC - 45oC
- Temperature overheat processor, when first turned on 60oC - 65oC
Nov 18, 2011 | Acer Computers & Internet
Hi....how can i repair my processor it is very fast to heat..then my computer is shut down....but i try to change my board... it is sane problem
remove the processor heatsink and the processor clean the surface and apply a thin layer of heat sink compound and fix back the processor and also check the processor fan is working if the processor is fauly the processor heats up quickly and shutdown the computer
Aug 04, 2011 | Compaq Pentium II , 266 MHz Processor
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
My hamilton beach food processor model 702r has a broken Blade. Is there a place to find the spare parts around Orange county in Southern California? The Blade itself is good but we overloaded the...
Goodmans, ebay and amazon by post
hamilton beach food processor blade 702 ' eBay
https://www.ebay.ca/.../i.html?_...0...hamilton+beach+food+processor+blade+702...
62 items - Hamilton Beach Shredder Slicer Disc Blades for Vtg Model 702-4 Food ... Hamilton Beach Food Processor Model 702R Parts Your Choice Blade Stem ...
hamilton beach food processor 702 blade ' eBay
m.ebay.ca/.../i.html?_...hamilton%20beach%20food%20processor%20702%20blade
48 items - Hamilton Beach Food Processor Scovill Model 702 Replacement Dough Blade. C $18.63. Hamilton Beach Scoville Food Processor 702-4 Replacement ...
Hamilton Beach Food Processor Parts ' eBay
www.ebay.com/bhp/hamilton-beach-food-processor-parts HAMILTON BEACH DUAL SPEED FOOD PROCESSOR MODEL 702-7 WORK ... Hamilton Beach Food Processor Shredder BLADE 702R Replacement Part.
Hamilton Beach Food Processor Blades ' eBay
https://www.ebay.com > ... > Food Processors > Hamilton Beach Food Processor Blades Results 1 - 48 of 348 - Hamilton Beach Replacement Parts Model 702-7 Dual-speed Food Processor Sears 400 7) Rubber Feet Set of 4 W/ Suction Cup GripSee ...
Hamilton Beach Blade Food Processors with Slicer ' eBay
https://www.ebay.com > ... > Hamilton Beach Blade Food Processors with Slicer Results 1 - 48 of 64 - Hamilton Beach Replacement Parts Model 702-7 Dual-speed Food Processor Sears 400 7) Rubber Feet Set of 4 W/ Suction Cup GripSee ...
Hamilton Beach Food Processor Model 702R Parts Your Choice ...
www.ebay.com > ... > Small Kitchen Appliances > Food Processors Hamilton Beach Food Processor Model 702R Parts Your Choice Blade Stem Lid Bowl ' Home & Garden, Kitchen, Dining & Bar, Small Kitchen Appliances ' eBay!
Hamilton Beach 702R food processor for sale on Ebay! - YouTube
? 1:08
https://www.youtube.com/watch?v=qS7jwpIPmqk
Nov 24, 2016 - Uploaded by Dave halverson
This item is for sale on Ebay. Check it out under the seller name Niterider!
Food Processor Parts - Goodman's
www.goodmans.net > Small Appliances > Food Processor Parts Replacement 3214-701-0001 Food Processor Belt fits Hamilton Beach 702R, etc. Our Price: $7.99 .... Kitchenaid Kfp79bl Multipurpose Blade for 9-cup Models.
Amazon.com: Hamilton Beach food processor blade post.: Food ...
https://amazon.com/hamilton-beach-processor-blade-post/dp/b000f38ire Hamilton Beach 68001800 blade post. Fits Hamilton Beach food processor models P70550, IG70700, 702, 702-7, 702R, 702RW, 702W-220, 702WS, 70300, ... hamilton beach food processor model 702r blade Google Search
Sep 17, 2017 | Hamilton Beach 702R Food Processor
I want to know about different cpu processor.how they are working and evolution of cpu processor
PROCESSOR IS BASICALLY KNOWN FOR ITS BEST PERFORMANCE AND SPEED. CURRENTLY AMD PROCESSORS ARE KNOWN FOR ITS BEST PERFORANCE AT LOWEST RATES. BUT IF YOU NEED A BETTER PERFORMANCE YOU SHOULD GO TO INTEL PROCESSORS. COZ TODAY INTEL PROCESSORS ARE THE WORLDS FASTEST PROCESSORS. THE ONLY LIMITATONS FOR THIS PROCESSORS IS ITS PRICE.
BUT IF YOU NEED TO PLAY GAMES AND WANT TO WORK IN MULTI TASKING YOU I ADVICE U TO SHIFT INTO INTEL PROCESSOR.
YOU CAN COMPARE THE BOTH PROCESSORS. JUST GO TO GOOGLE.COM AND TYPE COMPARE PROCESSORS IN SEARCH. THE RESULTS WILL SHOWS YOU THE SAME THING AS I SAID.
BYE
NICE DAY.
PLS. RATE MY SOLUTION.
KETAN
Feb 18, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
What processor?
Not all processors fit laptops. You shouldn't get a higher powered processor as you would then need to change the power supply as laptops are set to suit themselves.
Getting an intel may stop problems accoring.
Jan 14, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Processor compatability
Processors have a matched frequency rating with the motherboard and memory. So, when replacing or upgrading the processor, the new processor will need to have the same frequency as the old one. If the processors use the same type of memory, ie... PC2100, then ther are most likely compatable, and the use of a processor that was made for or from the same make of laptop is always a good idea. Some processors are designed specifically for use in certain manufacturer's system configurations. For example; say you have a Dell Latitude C840 with a 1.8ghz processor and you want to upgrade to a 2.2ghz processor from a Dell Inpiron 8600, this will work. Both of these machines use the PC2100 memory and have a matched frequency rating of 266mhz, and the processors are made for use in Dell machines. If you would like to tell me exactly what you're wanting to do, maybe I can recomend a processor for you. Let me know.
Jul 22, 2008 | AMD Computers & Internet
Overheating? Processor running at half speed?
If the PC boot and start I believe your processor is OK, it's very unlikely that a bad processor can start.
Normally the average temperature of a processor is between 40-50 degree C. Your processor is overheating and it will not last too long.
Please look at the link here below http://processorfinder.intel.com/List.aspx?ProcFam=483&sSpec=&OrdCode=
and see if you can reconize your processor. The number on the left is the same number printed on your processor (You have to remove the fan again).
As a second test I suggest you to download the Asus manual of your motherboard and verify that you don't have any jumper that you are missing.
If you want to post the motherboard type I can further help you.
Oct 23, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
