Question about Baumatic Dishwashers
We have a newly installed Beaumatic BYD1630 dishwasher and are trying to get it to work for the first time. The power supply is ok, but the program select button is not allowing us to set a program and so we can't get the dishwasher to work.
melnavz
  • 1226 Answers
SOURCE: Cannot set program
check the the circuit board for error, or clean it ..
also try unplug from the wall and let rest for a while some instance will resolve the issue. however, if the same issue occur then probably the circuit board got error and need to be replaced.
melnavz
Posted on Jul 28, 2008
  • 4 Answers
SOURCE: Candy dishwasher CDl 1012/2-80, program stuck?
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
Posted on Oct 04, 2009
  • 3247 Answers
SOURCE: The dishwasher is giving an E6 or is it F6 alert
If you are getting F6 flashing on the display then it means there is a lid fault. This is usually hard to fix by yourself unless you are already familiar with fixing these type of things.
Not sure why you worked out it is to do with water supply.
I can give you some instructions on checking what could be wrong with the lid but you will have to get the drawer out from the housing. I am assuming you have a single drawer unit. Let me know if you are interested in checking this or calling a technician.
Posted on Jun 25, 2010
SOURCE: hoover hnd315 dishwasher program buttons not lit or working.
I have the same problem, did you manage to fix it, and if you did what was the problem?
Posted on Sep 01, 2010
SOURCE: indesit dishwasher wont come on
this might be a little late but i ahve the same problem, an indesit engineer has been and there ia a metal bar the control wires rub against when opening/shutting the door. major design fault if you ask me. it tripped my entire kitchen and extention out.
Posted on Nov 09, 2010
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Beaumatic BDW10 Stopped before end.No error message
Reset it bgy unpluggin or by shutting off the breaker for five minutes. Then restore power and try again. Let us know
Jun 01, 2013 | Dishwashers
My computer froze in a program and won't reboot.
switch off ur computer and press f8 then go to safe mode and the remove all newly installed software and then try
Jul 09, 2012 | Biostar A760G M2+ Motherboard
Why does my beaumatic gas hob/electric oven keep tripping?
water has gone into back of element or oven light you will need to remove the back of the machine a check they are dry WITH THE POWER OFF
Apr 23, 2010 | Belling CookCenter 151 Dual Fuel (Electric...
hope this helps
regards JL
Oct 04, 2009 | Candy Dishwashers
BDW13 Element has broken. How do I replace as it's built in
Hi This is a design fault on the Beaumatic dishwasher - it has corroded four times on mine (a built in one) and we have had to have it replaced each time. They only seem to last about 2 years before they go. Although I had two corrode in one year! There isn't a lot you can do with it but I am thinking about replacing it this time for a dishwasher with a concealed element. The Beaumatic Engineer told me it was a common fault with them and to try and keep it wiped dry when not in use!
Jun 05, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Newly installed integrated dishwasher will not start
have you checked that the water inlet pipe is not kinked or that it is turned on. some models have water pressure sensors and wont work on low pressure supplys
Apr 26, 2009 | Smeg Dishwashers
GE 2200 Dishwasher-no power at all, circuit breakers are fine, switch works
with your volt/ohm meter check for power going to the dishwasher. the power supply is located under the kick panel. the power wire may be shorted out due to poor installation. if you are not comfortable testing power, I would advise calling a professional. If no power is found at the power box (this has a power cord or electrical wire going to it) the problem lies within your house electric. if 120 volts is present, check for power @ the door switch. aftrer that you just need to follow the power wire and see where it stops
If this is a newly built house and new to you the builder may have put a light switch above your counter ,the one you didn't think went to anything, check for that! good luck with it!
Oct 16, 2008 | Dishwashers
Dishwashers Logo
132 people viewed this question
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
