Question about Garmin nuvi 1300 Car GPS Receiver
My garmin 1300 says no map data available and will not navigate anywhere.
    Genius:
  • 1,043 Answers
Your map file may be corrupt. You can go to the Garmin website where you registered your unit, and download the same map. If you want to update to a newer map you can do that as well. To ensure that you have the correct map you will have to register your unit if you haven't already done so. Go to the following link:
https://my.garmin.com/mygarmin/customers/myGarminHome.faces
You will have to first make sure that your GPS is attached to your computer with the black USB cable that came with your unit. Plug the smaller end into the back of the unit and the larger end into one of your USB ports. The GPS will automatically power on. You will see a graphic on the bottom of your screen that looks like a GPS connected to a computer. A line will appear halfway up the screen which will start as a white line and then change to a green one. Once that is done you can register at the above site. The website will attempt to connect to your GPS so that it can read your model and serial numbers. It will then show you which maps are available for you.
Posted on Mar 13, 2011
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: my garmin nuvi 1300 says "no map data available".
This means is that the map file inside your Nuvi 350 is corrupted and the device can not read it anymore. We will need to update your map by plugging it into the computer. First thing you should know, with this problem that you are encountering most likely you will will need to send the unit back to Garmin to reload the map data onto the device, but I am going to try a few things with you to try to get it functioning again ok?
First thing to try is go to this webpage: Garman Map Updater, click on the "Check for updates" It will bring you to a new page, where you might need to install a plug in. It is okay to install the plug in and is nessesary.
If a map update is found you should be able to follow the instructions to update your map. Next I would like you to download "webUpdater" which updates the actual software on your device.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Nov 08, 2011
The garmin nuvi 1300 series comes on and then says loading maps and does it over and over and will not load maps
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 21, 2010 | Garmin nuvi 1300 Car GPS Receiver
1300 nuvi screen comes up loading maps and stops
I hope that helps.
May 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin 1300 says no detail maps found gps wont work with out it
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
May 09, 2010 | Garmin nuvi 1300 Car GPS Receiver
Reloading map Screen blank
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
May 04, 2010 | Garmin nuvi 1300 Car GPS Receiver
I hope that helps.
Mar 17, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin will not load maps
A Garmin Nuvi 1300 that won't start, or freezes on 'loading maps,' is symptomatic of having corrupt firmware.
I hope that helps.
Mar 07, 2010 | Garmin nuvi 1300 Car GPS Receiver
When i power it on it says loading maps and will not do anything
I hope that helps.
Feb 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
My NUVI 1300 has frozen at the "Loading Maps" screen. It also freezes when connecting to my laptop so I cannot perform an update. I've tried touching the bottom right while powering up and have erased...
I hope that helps.
Feb 12, 2010 | Garmin nuvi 1300 Car GPS Receiver
Well my Garmin nuvi 1300 was working fine yestarday but now it's saying "No Map Data Available"... What does that mean?
it sound like someone has "unticked" maps go to settings then maps and map info and look for the screen that says city navigator, and tick box that should work unless someone has attached to pc and wiped maps
Oct 24, 2009 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi 1300 Car GPS Receiver Logo
3,541 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
