My motherboard is Gigabyte 7VM333M-RZ. Want to upgrade RAM from 526 to 1GB. What DDR should I use - DDR, DDR2 or DDR3? Does this board support all these versions of DDRs??
  • 27,725 Answers
Http://www.motherboard.cz/ramsupport/
Support Memory RAM Compatibility
DIMM SIMM DDR DDR2 RIMM
Motherboard Mainboard MB Notebook
DDRRAM SDRAM RDRAM Upgrade
hope this helps
Posted on Mar 13, 2011
    Scholar:
  • 97 Answers
According to my info, you should buy DDR. Your motherboard will not support the faster DDR2 or DDR3 standards.
Does gigabyte7vm33mrz support DDR2 RAM? MY MOTHERBOARD (gigabyte7vm33mrz) SUPPORT DDR1 RAM .CAN i CHANGE IT WITH DDR2 RAM.IS IT POSSIBLE?
Not. your motherboard support only DDR1 memory RAM.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 25, 2011 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Will my Gigabyte GA-8I915P Duo Pro Motherboard take ddr3 and ddr2memory upgrades
This motherboard can take a DDR2 RAM , this are the supported RAM for it Dual Channel DDRII 533 / 400 or Dual Channel DDR 400 / 333.
Feb 11, 2011 | Gigabyte GA-8I915P Duo Pro Motherboard
Will gigabyte 7VM333M-RZ support 1 gb ddr2 ram ? thanks in advance for your answer
this information is from Gigabyte web site
Memory
  • DDR 333 (PC2700) / DDR 266 (PC2100) / DDR 200 (PC1600) 184pin
  • 2 x DIMM slots up to 2GB
For more information you can also visit the same http://ee.giga-byte.com/products/mb/specs/7vm333m-rz.html
good luck and do rate if got help
Dec 04, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
I have a gigabyte 7vm333m-rz ram ,i want to upgrade it, so can u tel me will my motherboard support upto 1gb ram?
yes:
  1. Type : DDR333 (PC2700)/DDR266(PC2100)/ DDR200(PC1600)-184pin
  2. Max capacity : Up to 2GB by 2 DIMM slots
This mainboard supports up to 2 gigabite of memory. Make sure you purchase memory that matches the memory you have already installed if you are not discarding the old memory.
Regards
Jul 25, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
I have Gigabyte 7VM333M-RZ Motherboard. Problem is no display and on beep without RAM.
all motherboad beep when u start motherboard without RAM
adn as far as you display is concerned it may be due to many reasond u have to specify all details of your problem
Jan 26, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Can i upgrade my ram to ddr3 if so what would you recomend .cheers
Thank you for the clarification sir.
NO, the Fujitsu Scalio 600 Media Center uses the Gigabyte GA-8ISXT-FS motherboard, and it only supports DDR Sdram.
This is a PDF Motherboard Manual for the GA-8ISXT-FS mobo, from Fujitsu Support,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/Boards/Motherboards/GigaByte/ga-8isxt/Man_8isxt-fs_uk.pdf
This is the support page for the Fujitsu Scalio 600 Media Center,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/consumer/MediaCenter/Scaleo%20600/Scaleo%20600.htm
Uses either DDR Sdram at 333MegaHertz, or 400MHz.
(PC2700 and PC3200 respectively)
DDR Sdram has 184 gold plated contact pins on the bottom.
DDR2 Sdram has 240 gold plated contact pins on the bottom.
DDR3 Sdram has the same amount of contact pins as DDR2.
The voltage and signal contact pins are in a different place, from DDR2 to DDR3.
This is why the locating notch on the bottom of the ram stick, is in a different place, comparing DDR2 to DDR3.
So you can see, DDR3 not fit in a DDR2 slot, because the locating lug in the bottom of the ram slot, and the locating notch in the bottom of the ram stick. Keeps people from trying to put DDR3 in a DDR2 slot, and vice-versa.
You can also see why a 240 pin ram stick, will not fit in a 184 pin ram slot.
Bumping up from DDR to DDR2 does make a difference in my book. (Requires using a motherboard that supports DDR2 however, so you would need a different motherboard)
Going from DDR2 to DDR3? Not so much IMHO. The frequency rate is higher, but there is a trade off with slower ram timings.
Sorry if I have been too 'Windy', but I thought I would give you more information, than just,
'No, won't work', or No won't work because your motherboard uses DDR Sdram'.
Nov 18, 2009 | Televison & Video
Is DDR2 Compactible with gigabyte 81845ge-rz motherboard?
No. If the current RAM is DDR, then DDR2 will not work.
The slots are slightly different, and the DDR2 won't even fit into a DDR slot.
Apr 28, 2009 | Computers & Internet
Ddr ram
welcome to fixya
if something burnt out most of the time the mother board is gone (junk) if nothing eles try to remove the new memory and try to reboot if still nothing happens then you fried the motherboard
sorrry to hear this
have a good day other wise :)
Jul 31, 2008 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
