Question about HP Compaq nc6000 Notebook
HP Compaq NC6000\r\nWhen I press the power button it seems to start but the only thing I see is numbers going by rapidly in the form of kbytes (524288 KB ok) then it reads 162-system Options not set. Then below that it the config was auto updated it lists total memory then says (CMOS checksuminvalid, default values loaded) and then you can press F1 F2 orF10, but actually you can't because its stuck and thats as far as it gets. Any suggestions? Help Please!
    Genius:
  • 1,189 Answers
Hi promano67
When you "start" the computer, and the {"Screen"} displays a "Error Message."[CMOS] "error checksum!"
Settings: "Default" loaded.A "checksum error" shows that:
The ("Boot-up Settings "have been changed?"), ie. "Booting OS."
*Boot File 'missing'.
"This can 'occur' if the computer was "shut-down unexpectedly."
Force Shut-down : Power lost; due to 'low battery...'
A ("Power Surge") can cause this 'problem' also.
"What 'happens is that the [CMOS] settings are lost!".
"To fix the problem!"
Do the following:
  • "Restart / Boot the computer.
  • Next, verify if the 'error message' displays?
  • If you are still getting the message?
  • "You will have to "Remove the CMOS battery form the computer!"
  • Shut-down the computer.
  • "Unplug the computer from the {Wall Out-let}.
  • Remove the Lithium battery from the "Notebook."
  • There is a compartment (underneath) the "Notebook that 'store' the CMOS battery."
  • "You will need a {very small Phillips screwdriver}.HP Compaq NC6000\r\nWhen I press the power button - _953.jpg *Remove the CMOS battery for: [30 minutes].
  • !Important: If you have to do it again?
  • Remove the CMOS battery for a {'longer amount of time'}.
  • Replace the "CMOS battery."
  • Next, "Only plug the Power Adapter into the computer.
  • "Do not - replace the "Lithium battery!"
  • Once you have completed these 'task'.
  • "Restart the computer."
  • "Press the [F2] key, to 'enter' the CMOS / BIOS Setup!" _951.jpg
  • Next, 'reset' (all) "Values to the Default Settings."
  • "Press the [F10] key to 'Save' the changes!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Posted on Mar 13, 2011
  • paul7of9
    paul7of9 Mar 18, 2011
    This 'comment' is for FixYa! So my understanding is; -10 is {subtracted} for "Not Helpful: Solutions!" But! When the "Solution is Very Helpful! = 5 or < LESS!" ? Is this "Correct"!? I have another ?Question? Do a number between a (100 to 1000) people respond quicker, and more to "Solution that do not help!" In comparison to the "Solutons that do?"
My HP nc6000 wont start when I press power button. Fan starts for a few seconds an then the orange led turns on, after that everythig turns off. AC an the battery is ok. Any idea? Thak you.
Hi,these particular brand of Hp series is very problematic,try checking the Ram out,its usually underneath the keyboard,so if you have two installed try using one at a time to boot system,if problem persist have an I.T Technician look at it.
Dec 31, 2010 | HP Compaq nc6000 Notebook
Non system disk or disk error
it seems that your hard disk is not getting in to Operating System. All you need is to check your drive thoroughly and reinstall OS....reason could be any thing, may be some virus has deleted system files or your drive may have develop some bad sector...
Nov 23, 2009 | HP Compaq nc6000 Notebook
Hp wlan 802.11a/b/g W500
goto to google search for HP nc6000 drivers you can download your drivers form there. please dont forget to vote
Nov 20, 2009 | HP Compaq nc6000 Notebook
Hi, i have compaq nc6000 when i press the power button the laptop was on but desktop item does not show and any command does not work, pls give proper solution
when u power up the laptop press F8 key then enter in safe mode .
then go to start menu then type in run "chkdsk /r"
then press "y"
then restart it and it fix error on harddisk.
Also check in your computer that there are not 2 antivirus installed.if u found 2 remove 1 in safe mode.
Jun 12, 2009 | HP Compaq nc6000 Notebook
HP Compaq nc6000 wont start up
Hi there.
This could be a problem with the system memory.
Take the battery out and the AC power, turn the laptop over and look for a panel with screws on it, unscrew the panel and you should see something like this >>>>>>>>>
Unclip the memory by pushing the little lugs outwards and the memory should pop up ready to be taken out, get a clean dry paintbrush and clean the memory and the slots.
If you have more than one stick of memory just put one of them back and try booting the laptop up.
If one works try the other and see how you get on.
Post back for any additional help
Good luck and thanks for using FixYa!!
May 26, 2009 | HP Compaq nc6000 Notebook
My pc doesn't startup up
I had this problem too but I then downloaded the most recent BIOS driver from the HP web site and that seems to be working. At least it now starts and boots correctly but I still have the problem that it tends to hangs up after a short while.
May 01, 2009 | HP Compaq nc6000 Notebook
Can sumone plz tell me wen i start my hp compaq nc6000 orange light come n thn shut down it dont boot bt after many time it get started n after sumtime the screen disapear plz tell me whats this problem
if you press on the top right corner near the pg up button on my set, it boots up fine but release the pressure and the screen goes blank but LED and HDD still hums. I got a guy to resolder the Maxim power regulator chip (BGA) on underside of the mobo. Now the set works fine. seems that opening and closing of the lid causes pressure and flex on the mobo and that in turn causes the BGA to "crack a lead". Only problem is locating the guy with the right tools to do it in your area. Got mine fixed on a recent trip to China
Feb 21, 2009 | HP Compaq nc6000 Notebook
HP COMPAQ NC6000 notebook HELP ME PLS
restart with os in drive
constantly click F8 options will come up highlight the option to boot from cd or cd/dvd then enter
if that don't help let me know
Jan 07, 2009 | HP Compaq nc6000 Notebook
Cant get past power up on my nc6000 hp
Here's how to do it. Read this forum link:
http://www.techimo.com/forum/mobile-computing/126058-hp-compaq-nc6000-problems-4.html
There's a few things you need to do besides removing the CMOS battery. Get a couple of small screwdrivers out, you are going to need them.
Nov 29, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
1,112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
