Question about Electric Mobility 4 Wheel Heavy Duty Mobility Electric Power Scooter
Warning triangle flashing - Electric Mobility 4 Wheel Heavy Duty Mobility Electric Power Scooter
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
WWW.ALLDATASHEET.COM HAVE A NICE DAY FROM COLIN.
Posted on Mar 14, 2011
I have a 2002 Mercedes CLK 320. I got a flashing yellow triangle on the dash with a loss of power for 5 seconds. This is happened twice in the last 2 months . What could be causing this?
Hello Loss of traction. The stability and traction control systems took over. Should go away after a very short while though.
The flashing triangle warns the driver that a wheel is slipping. If its on steady it means that the ESP is switched off.
The loss of power is for the vehicle to regain grip and to stop the tires or tire from slipping
Dec 14, 2016 | 2002 Jeep Grand Cherokee
How to reset service warning lights
Turn key to position I
Then press and hold odometer button
Turn key to II and wait for the triangle to start flashing before releasing it whilst still flashing.
It makes a beep sound and the message disappears..
May 13, 2014 | 2006 Volvo XC90
What does a flashing Red triangle mean?
TCO means that the tachograph does not work properly. Because the european legislation is very strict regarding the malfunction of the tachograph system, the truck manufacturers alert the driver about his critical situation with a warning sign, the red triangle that flashes.
Apr 16, 2014 | Bruder MAN TGA Container Service Truck
Flashing triangle
It's a warning. It should accompany a warning code or message
Sep 24, 2013 | Canon Office Equipment & Supplies
Porsche Indicators Lights Flashing
switch off the flashing warning light to the right6. It has a red triangle on it.
Apr 21, 2013 | 2001 Porsche 911 Carrera
Yellow triangle with ! in the middle popped up on dashboard what does that mean
It's the ESP warning light, You may have a ESP button on the dash which you can push to reset it, Otherwise try having the car idling in neutral and turn the steering wheel fully left then right the back to middle, This should reset the light, if it comes back you will need to get the car plugged into a diagnostic scanner to find the issue.
Mar 04, 2012 | 2001 Mercedes-Benz C-Class
Yellow triangle with ! in middle popped up on dashboard what does that mean
Hi there:
this is the ESP warning triangle and is normal , what this is is when the wheels start to slip even very slightly the triangle will flash , if you look at your switches on the dash there will be one that says ESP off , if you press this the triangle comes on solid , press again and it goes out.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Volvo c30 How do I reset the maintenance remider message.
1. turn ignition to I
2. depress and hold trip button
3. turn ignition to II(while still holding trip button)
4. in about 5-7 seconds warning light(yellow triangle) begins to flash
5. release trip button WHEN yellow triangle is flashing(it flashes 5 times, if you wait for it to stop flashing, it will NOT reset), turn ignition off
Mar 02, 2011 | 2008 Volvo C30
There a yellow triangle light on dash
This triangle might be the warning light that the traction control system is switched off. to switch traction control back on again, locate the button to the lower right hand side of the steering wheel, down beside the headlamp levelling switch. The button should read VSA OFF. With the engine running press this button and the lamp should go out. Note that in slippery conditions when the front wheels start to spin this triangle will flash as the traction control kicks in. Hope this helps. Stuartie.
Nov 09, 2010 | 2008 Honda Accord
Need to know what the warning light on dash means
The flashing dash light is a warning about a failing system, most likely the fuel system. On mine it was the oxygen sensor on the way out. You need to do the diagnosis process with the ECU and this will report back the code that will tell you precisely what's the problem. You'll find the ECU diagnosis procedure here at the 300ZX online factory service manual.
Hope this helps.
Oct 08, 2008 | 1990 Nissan 300ZX
Electric Mobility 4 Wheel Heavy Duty Mobility Electric Power Scooter Logo
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
