Question about LG 42LC2D 42 in. LCD HDTV
It takes turning the tv off and on 3-4 times for it to work
  • LG Master
  • 2,098 Answers
Hi bsatkins88,
This is an indication of out-of-regulation in the power supply section. This was caused by leaky/dried electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit.It needs a little warm-up to make itself stable but the symptom will get worst. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Your unit will back to normal again if the leaky capacitor is isolated.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
You may also replace the entire board for your convenient http://shop.ebay.com/i.html?_nkw=LG+42LC2D&_sacat=0&_odkw=53UDX10B&_osacat=0&_trksid=p3286.c0.m270.l1313.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 13, 2011
Emerson tv problems
sounds like a button problem, your remote seems to be in programming mode,
I would take apart and clean,
Take batteries out 1st.
# 2 Take a Q tip with rubbing alcohol and swab your keys.
# 3 use some compressed air to blow out and dry keys.
# 4 Re- set your TV to factory reset.
Power tv up and follow instructions to remote set up.
Jul 18, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Do not know how to program the systemlink3 universal t,v. remote control to my t.v.
Option 1:
To clear things up and make it simple, here is how to program the RCA Systemlink 3 remote:
****WITH DEVICE TURNED ON****
  1. Press and hold the "Code Search" button until the LED lights, then release. LED will stay light.
  2. Press and release the device key to be programmed. LED will go off when button is pressed and back on when released. LED remains on.
  3. Press and release the remote On/Off (power) button as many times as required to turn your device OFF.
  4. When device turns OFF, press and release the ENTER button.
Test remote on device, if ALL functions do not work, repeat above procedure.
***IMPORTANT NOTE***Count how many times you press the On/Off button. If ALL funtions do not work and you need to repeat, you don't want to stop at the same non-working code. For instance, if it takes 23 times to turn your device off and after testing, the remote does not control all functions, repeat steps 1-3 BUT when the device turns off at the 23rd time, turn it back on using the power button ON THE ACTUAL DEVICE then continue with step 3 and 4 from above.
Option 2:
Thanks for the hints on your web site. For the RCA SystemLink 3 with the key pad, I could not get the sequences described to work. But they did point me in a direction which worked for my remote:
  • With the TV on (for TV)
  • Press and hold code search until the light stays on
  • Press TV (for TV) button once
  • Press the on/off button once
  • Thereafter, the light will stay lit and every couple to three seconds it will blink twice indicating it is trying another code.
  • When the TV turned off, I pressed enter. Thereafter the unit worked.
May 04, 2011 | RCA Televison & Video
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My TV won't turn on.
If this is a RCA Picture Tube Rear Projection, the Deflection Board will cause this problem. I do not know though if it is available.
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
Issues program the remote.
go and buy another remote as this is the most useless waste of time when you keep getting the run around and no answers.what does it take to post a page with all the remote numbers on it they all come with the same page.
Sep 30, 2008 | RCA RCR311B Remote Control
Hitachi Ultravision 60" rear projection
Time for a new TV. I have searched for manuals and parts. What is available is expensive and may not fix the problem.
Apr 27, 2017 | Hitachi 60SBX72B 60" Rear Projection...
Tv turns on but takes about 20 minutes to show the picture
This is the picture tube. If you check shops you can find one that has a picture tube restorer. If they run just the cleaning process it will buy you some time. This is good some times for up to a year
Apr 19, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Codes for sylvania tv
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
Feb 10, 2008 | Zenith ZEN450 Remote Control
TV will not turn on.
Bite the bullet, because it's time for Santa tech to work on this and find the reason for the power supply problem..accordianman
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Sony KV32FS120 32" FLAT TUBE SDTV
Replace Shorted D500 And D503 Sony p/n# 871908100 or NTE571 will work as a good sub. Also Replace Q512 Sony p/n# 872980929 2sc4159.
Parts will be about $17.00 dollars and takes about an hour if you're thinking of taking this to the shop instead...
Bill
Dec 12, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
LG 42LC2D 42 in. LCD HDTV Logo
81 people viewed this question
Computer Repairing
Computer Repairing
