Question about Refrigerators
I just purchased a 2.7 refridgerator a white wire inside the fridge was hanging down with a bend on the end. Now items left os shelves freeze. We can not see were this wire attaches
    Guru:
  • 683 Answers
Sounds like you are looking at the thermostat cap tube.
Posted on Mar 13, 2011
How do I reinforce freezer shelves?
The freezer should not be totally be full otherwise the cooling system will not succeed to reach its design temperature. If the shelve is still bending, get a piece of maple about 1x2" and attach it to the shelve at each end with a piece of nylon rope.
May 01, 2014 | General Electric FUF21SVRWW GE 20.6 Cu....
Why is refridgerator freezing items on lower shelves and in drawers?
Joe can you look inside and check the air damper for any signs of blockage? It is also electric controlled by your thermistor and motherboard. I believe if someone has not removed the tech sheet from its location after removing top cover I can answer most of your questions from here. Click Here=> Page 1 Lot of people enjoy fixing it themselves so we will give it a try. Now Click Page 2 now the Wiring Diagram=> Page 3 Now on this page look at symptoms listed as=> Refrigerator Compartment Too Cold Then next to last page=> Here and last page HERE You are welcome to contact me here or through my sites. The site server was not up and running for some reason or I would have answered sooner. If helpful please rate if not ask questions.
If you need the Service Manual E-mail me Here=> appl...@yahoo.com or I can walk you through the repair over the phone, Thank You, John Tripp
http://whirlpoolmaytagcustomerassistance.blogspot.com/
Nov 18, 2011 | Refrigerators
We just purchased this model, and the items in our refridgerator keep freezing, including the milk in the door. We have turned down the setting to 2 and it keeps occuring, is this common? Mostly things...
I've actually ran inti this problem alot. its just a design flaw. the objects that are freezing are close to the direct flow of cold air coming from the freezer into the fresh food compartment. adjusting the temperature will result in the same condition. The only thing you can do is rearrange products closest to the air duct. You may even gave to rearrange the shelves. Just ran into this same problem yesterday when i was dispatched to a customers home. Its just a stupid flaw in the design of the fridge.
Feb 08, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Refridgerator won't cool on propane. Lights fine and stays lit. Stack gets hot. Coils are warm. Works fine on AC and DC.
I had a similar problem. The flue would get hot and the cooling tubes would get "warm". The refrig would get a LITTLE cool but nothing to be of any help.
I solved it though...it turns out there is a "flue baffle" (twisty little metal thing) that is supposed to hang in the inside of the baffle. It hangs from a screw found on top of the baffle and it is supposed to hang down.
The screw that held mine was corroded and flue baffle had fallen into the baffle and landed on top of the burner.
I ended up fishing the flue baffle out of the top of the baffle with a coat hanger, then rehanging it using a new screw. That solved my problem.
Not sure if this will work for you or not but good luck.
By the way, you can find an owner's manual with a diagram showing the flue, the flue baffle, and the piece of metal holding it here:
http://www.fourwheelcampers.com/DometicRefrigerator.pdf
Look on p.9, figure 9. Item C is the flue baffle and the wire holding it. Item B is the screw that was corroded on mine, and ended up dropping the baffle down to the bottom of the flue.
Below is a link to some generic directions on solving fridge-related problems. I found it to be VERY useful.
http://rvmobile.com/Tech/Technical.htm
Jul 12, 2010 | Dometic RM2193 Compact Refrigerator With...
Refridgerator is freezing everything
This is likely a thermostat failure. The thermostat is no longer shutting down the compressor or sensing the temperature wrong. The thermostat is a module inside most modern refrigerators and is a fairly easy fix except for the cramped quarters. You can order the thermostat from an appliance repair store. I suggest getting the service manual while you are at it if you have no experience taking a fridge apart.
Do not damage or bend the sensing tube sharply at any time. Be gentle!
Mar 22, 2010 | Amana Refrigerators
Water pooling in the fridge.
excess water usuall y means there is a blocked drain tube in the bottom of the fridge.this can be cleared by using a small bottle type brush and run down through the drai hole to clear it.also check the drain tube from the rear of the fridge and make sure there is no obstruction near the drain pan
Feb 24, 2010 | Refrigerators
The Dometic DM2652 doesn't have temperature controls. My 2008 model freezes alomost everything on the top two shelves of the refridgerator. I use a low volume air circulator. Is there a way to lower the...
I have the same model in my 5th wheel. I found a white plastic piece on the far right side of the metal slats inside the refrigerator. This plastic piece has some kind of a probe attached to it. The white plastic piece slides up/down on the metal slat. There is a sticker next to this thing on the right side of the refrigerator (inside) that shows a range of "colder to coldest". I think if you slide that piece up/down, that is what controls the temp inside the frig.
Jul 12, 2009 | Dometic RM2652 Refrigerator
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Refridgerator is not cooling properly
Ours does this too; it says its 34 degrees but really its 53-58 degrees. . . The compressor coolant part of the machine freezes and then it can't circulate the cold air to cool the fridge. You have to unplug it for at least 24 hours to let it thaw, or you can take out the lower drawers and shelves, unscrew and remove the lower back pannel (from the inside of the fridge). We use a blow dryer to thaw out the ice block that formed on the unit. It goes faster if it is unplugged, this fridge is horrible we lost hundreds of dollars in groceries before we figured out the problem.
Dec 26, 2007 | Samsung Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
