Question about Microwave Ovens
Getting no power & it's not the outlet - Microwave Ovens
  • Microwave Ovens Master
  • 6,771 Answers
The main fuse in the microwave oven has blown and is often caused by a defective door switch.
Posted on Mar 13, 2011
I have a 2000 23ft comfort travel trailer, it is pluged into electrical, all lights work, but I do not get any power from outlet plugs. I checked breakers & fuses, no outlets work.
On my trailer the gfci is a seperate button in the fuse panel that shuts down the 120v outlets, all the lights run off the 12v so they continue to work, does your microwave and ac work?
Mar 02, 2015 | Microwave Ovens
Scholtes oven
try moving the unit to a different power outlet, it might not be getting enough power = AMPS .. should be a easy fix. good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
Aug 13, 2013 | Microwave Ovens
I have a GE Spacemaker microvave oven that was working perfectly for the past 4 years. When installed, we were told that the outlet did not work, so to get the microwave working, the cord was pulled out...
Perhaps the microwave's main supply fuse has blown.Open the cover & check it in the power supply section.Be careful & discharge the big capacitor first as there is very very high voltage present inside even after switching off.
Mar 07, 2012 | GE Spacemaker Over-the-Range Microwave
I was cooking food for 1 minute and it just shut off after approx. 30 sec. There are no lights or power now. The outlet is fine. The unit is 4 yrs old.
Check your other appliance. You may have tripped a break. If they are all functioning, and you have no dead outlets in your kitchen, then the unit will need to be serviced. Hope it's the breaker.
a 1200w microware will draw 10 amps all by itself. Your outlets are most likely on 15 amp breakers, so it wouldn't take much amp draw from another kitchen appliance to trip the breaker.
May 11, 2011 | Dacor DMT2420SS Microwave Oven
Microwave is not getting power but outlet is okay
your internal fuse is open on the unit it takes a 10-15-or 20 amp ceramic power fuse
Sep 27, 2009 | Microwave Ovens
Just quit. No power, no display....nothing
there are several possible causes, check voltage at outlet
check the 20 amp bus fuse on the main board ohm out the cavity thermostat, replace the bad part
Sep 10, 2009 | Samsung MS1040BB Microwave Oven
Hi I'm thinking of getting an OTR mictowave and was wondering if I have to install an outlet in the cabinets or can I just place it where the existing wires for the hood fan are. This location would be...
The outlet needs to be in the cabinet above. The microwave needs a dedicated circuit. Turn the power off to the hood and see if any lights or outlets go off on the same curcuit. If only the hood is on that line your good to go with that wire if it meets requirments. Our code asks for 15 amp breaker and 12/2 grounded wire. If it meets your local requirments, just take it up inside the wall to your new outlet location(usually there is enough wire to reach) and install a box, outlet and cover.
Jul 23, 2009 | Microwave Ovens
Blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
May 21, 2009 | Emerson Black Microwave Oven
Problem with electrical source
Does your manuel also tell you to use a DEDICATED 20amp circuit to plug your Microwave in to? More that likely you used a 15 amp circuit that other appliances were also plugged into. A refrigerator or other cooling item needs its own 15 amp circuit but can tolerate small amp draw items like a clock. The new, higher wattage microwaves need a 20 amp circuit for itself. Have your line checked , have your microwave fixed. Start new
Aug 26, 2008 | Microwave Ovens
Microwave Ovens Logo
11 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
