I have an Acer 6920 and just yesterday I went to go turn it on with the power supply plugged in and connected to the outlet and the light near the power button flashed orange and my laptop wont turn on. The same light near the power button that flashed orange is now blue like it is supposed to be but the computer wont turn on, no fans and the disc drive doesnt even spin nothing happens at all. Need help with this to figure out what happened and if \i cna fix it myself. I have already tried taking out the battery and keeping the power suppl conected and holding the power button down for 30 seconds and still nothing happens only getting that blue power light indicating that the laptop is plugged up and getting power. Thank you, Carla
  • 55 Answers
Hello Carla, It seems that there is a power problem, only it's not very clear where exactly it lies. Does the laptop power up with the battery only (unplugged from the power supply)? If it does, then it's probably a power supply problem and that could be replaced rather cheaply with a new one. If it doesn't start using the battery only, then it's most likely a problem on the laptop itself, which means it should be serviced by someone with the appropriate technical skills.
Posted on Mar 13, 2011
    Scholar:
  • 97 Answers
Sounds like a malfunction in your power supply. I would suggest contacting Acer support and informing yourself about the warranty on your device.
Don't forget to rate this comment - give me thumbs up if you liked this advice!
Acer aspire 6920 just went off yesterday abruptly. no power with or without the battery. no power when just using the power cord. I tried removing the battery and ressetting the power button ( no luck)....
Take the battery out and short the pins. If this doesnot work than seems your power adapter is problem. It is not charging the battery. Check if your power adapter is OK. If it is ok than looks like the power jack pin is open. Take it to repair center to have the Jacks fixed
May 12, 2010 | Acer Aspire 6920-6621 Notebook
I have a 13 month old Acer Aspire ax1700 Desktop. Had turned it on yesterday and Fan was making lout noise. Today I turned it on to check it. Was on for about 10 minutes and it just turned off. There are 2...
It seems that the power supply unit has gone. If you power it on and nothing happens then obviously the psu has gone. The heat that you felt was the psu overheating because of no fan and hence no ventilation. The noise was of the faulty psu fan that got stuck or did not work and the psu got overheated and got burnt eventually. Please replace it with a new one as a repaired psu may work but you cant rely on it.
Mar 22, 2010 | Acer Aspire AX1700-U3793A PC Desktop
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
Laptop is plugged in. Notice on screen that battery was low, even with it plugged in, and now no power lights on. Adapter light is still on indicating outside power supply on. Removed and reinserted...
The batteries do go bad overtime and will no longer hold a charge but the laptop should still work as long as the power cord is connected. If it still does not work with the power cord connected then it is most likely the power cord, these can go bad, but make sure that the power is securely connected and that if it is plugged into a power strip that it has not been turned off, try another outlet just to rule it out as well.
Jan 22, 2010 | Dell Inspiron B130 Notebook
My Acer Aspire 6920 will not turn on. when I plug it in the power supply light comes on, but the blue light where it plugs into the computer does not. It does not turn on with or without being plugged in....
I think this might be a battery issue, if you can get a hold of another battery try swapping them and see what happens.
post back and tell me what happens
Jan 20, 2010 | Acer Aspire 6920 Notebook PC
Got new battery for acer aspire 6920. not charging
You ordered the wrong battery, theres two types, your original would have been 11.1v if you check the new one it will be 14.8v. They are not compatable.
Nov 19, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 6920 will not turn on. With or with out hard drive inplace. Pushing power button makes the keyboard lights come on but not the computer screen or hard drive. Pulled hard drive and connected to...
I had same problem with my aspire 6920.Tried power reset didn't work. Tried replacing memory chips,No go . Pulled rest of my hair out,still nothing . Then I checked memory chips again and noticed that the inner chip was not seating correctly due to a design flaw in the retainers. Gave both retainers a gental tweak,reset chips. And most importantly Disconnected CMOS Battery and held power button in for 1 min. Plugged everything back in and Bingo... Fired right up >>>And to the comment about plugging in the HD ....Mine fired up with out it ..
Jun 18, 2009 | Acer Aspire 6920 Notebook PC
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
