Question about Sony Cyber-shot DSC-W300 Digital Camera
It is not switch on. - Sony Cyber-shot DSC-W300 Digital Camera
  • Sony Master
  • 2,517 Answers
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Posted on Mar 13, 2011
What's the difference between digital switches and analog switches?
Basically, the exchange of digital and analog Huawei switch mode, there is a difference between digital switch USES time-division switching, analog switch is the interchange of air separation.That is to say, the way of digital switches is non-blocking switching, analog switches have rope limit of the road.
Nov 03, 2015 | Electrical Supplies
Lights not working @ top of stairs
Pull the covers off the switch boxes and remove the switches but don't disconnect them. Look to see how many wires are connected to each switch. A two way switch should have 3 insulated wires connect to each switch AND a bare copper wire for ground. If you don't have that configuration, then it was not built correctly.
Jun 28, 2015 | Home
Advise: Cisco Switch for small business?
I think Cisco Catalyst 2960 & 2960S Series Switches with LAN Lite, Catalyst 2960 Series Switches with LAN Base, and Catalyst 2960-S Series Switches with LAN Base is best choice. You can get more information in http://www.3anetwork.com/blog/cisco-switches-for-small-business/
Aug 04, 2014 | Computers & Internet
I changed light switch and fan switch quit working. The fan switch is its own station and then the light switch is on its own station right beside each other
Did you take photo of wiring before disconnecting old switch...you might have wired wrong.
Rewire old switch and see if same problem exists.
Check that new switch is rated for same device.
Attach 2 photos of old and new switches, each wired...so expert can see problem better.
http://waterheatertimer.org/How-to-wire-switches.html
Test that fan switch is getting power.
Gene
Sep 12, 2013 | Cooper Wiring Devices Motion Sensing...
How do I wire a 4 way switch in my home
in order to wire a 4 way switch, there needs to be a total of 3 switches working to operate a device/light. you need a 2-wire coming from power source, 3-wire from first switch to 4-way switch then 3-wire to last switch. white wires (neutral) get connected together. Depending on the layout of the switches. i.e where the power comes from and where the switch leg goes to but a basic 4 -way switch is in between 2 other 3-way switches.
Jan 08, 2013 | Leviton Decora Gray Rocker 4-Way AC Quiet...
Kexus ignition switch replace
To troubleshoot these issue, for ignition switch replacing procedure:---
Click the link below:---
IGNITION SWITCH REPLACING
It depends on vehicle to vehicle. But it's not very difficult on mot of cars to replace ignition switch. Basic theory of replacing ignition switch is same for all car models. -----
To replace ignition switch on your vehicle, I suggest you few helplinks with proper ignition switch replacing procedure. View its details and you can replace ignition switch on your vehicle.
Click the link below: ------
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to replace Ignition Lock Cylinder on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-lock-cylinder.html
Ford Taurus: Ignition Switch & Steering Column Replacing?
http://repairhelpcenter.blogspot.in/2012/06/ford-taurus-ignition-switch-steering.html
How to replace Ignition Switch on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-switch-on-acura.html
How to Replace Ignition Switch on Chevrolet Caprice Classic?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
Dec 06, 2012 | 1993 Lexus Es 300
How to replace ignition switch
It depends on vehicle to vehicle.But its not very diffult on mot of cars to replace ignition switch.Basic theory of replacing ignition switch is same for all car models.:-----
To replace ignition switch on your vehicle,i suggest you few helplinks with proper ignition switch replacing procedure. View its details and you can replace ignition switch on your vehicle.-------------Click the link below :----------------
1995 Ford Taurus: Ignition switch not turning OFF? http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Switch Will Not Turn Off? http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
Nov 25, 2012 | Cars & Trucks
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
THE "SWITCH" GOES BAD EVERY
Please look at the list below, keeping in mind that this is not an exhaustive list of the switches that your vehicle is equipped with. After staring at the list for a while, tell me what is wrong with your question.
>> A/C High Pressure Switch
>> A/C Low Pressure Switch
>> A/C Refrigerant Pressure Sensor / Switch
>> Ambient Temperature Sensor / Switch HVAC
>> Blower Motor Switch
>> Brake Fluid Level Sensor/Switch
>> Brake Fluid Pressure Sensor/Switch
>> Brake Light Switch
>> Brake Switch (Cruise Control)
>> Cabin Temperature Sensor / Switch
>> Combination Switch
>> Coolant Temperature Sensor/Switch (For Computer)
>> Cruise Control Switch
>> Door Jam Switch
>> Door Sensor/Switch (For Alarm)
>> Door Switch
>> Driver Information Center (DIC) Switch
>> Engine - Coolant Temperature Sensor/Switch
>> Fog/Driving Lamp Switch
>> Fuel Door Switch
>> Garage Door Opener Switch
>> Glove Box Lamp Switch
>> Hazard Warning Switch
>> Headlamp Dimmer Switch
>> Headlamp Switch
>> Heated Glass Element Switch
>> High Pressure Sensor / Switch
>> Hood Switch / Sensor
>> Horn Switch
>> Ignition Switch
>> Ignition Switch, Buzzer
>> Low Pressure Sensor / Switch
>> Neutral Safety Switch
>> Parking Brake Release Switch
>> Parking Brake Warning Switch
>> Power Door Lock Switch
>> Power Mirror Switch
>> Power Seat Switch
>> Power Window Switch
>> Pressure Cycling Switch
>> Rear Defogger Switch
>> Remote Switch
>> Seat Belt Buckle Switch
>> Seat Heater Switch
>> Seat Memory Switch
>> Shift Interlock Switch
>> Sunroof / Moonroof Switch
>> Telescoping Wheel Switch
>> Tilt Wheel Switch
>> Traction Control Switch
>> Transmission Mode Switch
>> Transmission Temperature Sensor/Switch, A/T
>> Trunk / Liftgate Switch
>> Trunk/Liftgate Sensor/Switch (For Alarm)
>> Turn Signal Switch
>> Underhood Lamp Switch
>> Valet Switch
>> Washer Fluid Level Switch
>> Windshield Washer Switch
Aug 17, 2011 | 2001 Cadillac DeVille
With the switch in the up position(toward input screws on back) and placing the ohm meter probes; one on the upper left, one on the lower right, continuity is read. Reversing (one lead on upper right, one...
I answer questions for free.
I understand electrical devices.
It is unclear how many screws are on the switch you are testing.
If your switch does not show ohms when the switch is in one position, then it sounds like the switch is bad. But you can read information below for more information about your testing.
You can also add a comment and continue the discussion.
Let me provide more information about switches because you seem interested in electricity and the information may help us understand where the other is coming from in case you add a comment needing more help:
2 screws on switch: (excluding ground screw)
An ordinary single-pole switch usually has 2 brass colored screws.
These screws only read ohms or continuity when switch is in one position.
When the switch is in the other position, there are no ohms that pass through the switch.
3 screws on switch: (excluding ground)
A 3-way switch has 3 screws. There are 2 brass-colored screws and one dark-colored screw.
Put ohm tester on dark screw and continuity will show between the dark screw and one of the brass screws.
Flip the switch and ohms will test between dark colored screw and the other brass screw.
4 screws on switch. (excluding ground)
There are 2 screws on each side of switch.
This type of switch might be a special purpose double-pole switch.
Or it might be the more common 4-way switch.
Add a comment if you have a switch with 4 screws.
Below is a typical 3-way switch application showing the dark-colored screws:
Here is a typical 4-way switch circuit:
Notice the switch in middle has 4 screws:
Link below goes to a special application double-pole-double-throw switch:
http://waterheatertimer.org/images/30-Amp-DPDT-switch-a-800.jpg
Nov 01, 2010 | Leviton Decora Gray Rocker 4-Way AC Quiet...
Sony Cyber-shot DSC-W300 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
