Question about Insignia Televison & Video
I just bought a 42' 1080p with an HDN1 Cable for my PS3. Everything works fine and looks and sounds great until I try to play a game. When the TV enters game mode there is absolutely no audio. How can I fix this problem?
SOURCE: PS3 not working through HDMI cable
connect PS3 to TV select HDMI channel on TV press AND HOLD power button on PS3 until screen resolution selection page appears.
PS3 should now work.
had this problem, this solved it.
typical repairman looking for work :)
Posted on Jun 29, 2008
SOURCE: playing psp game in tv using component av cable
The Television must support Progressive Scan or else it wont work. I just bought a cable myslef and found this out the hard way.
Posted on Aug 12, 2008
SOURCE: Ps3 not playing blu ray on my samsung LCD
Change the frame rate on your tv to 60hd, that should solve it. Basically, your tv might be set to theater mode which is playing 24hd..
Posted on Jan 02, 2009
jhall1793
  • 60 Answers
SOURCE: "No Signal" for PS3 using HDMI cable
jareddirk30:
you didn't mention what software version your ps3 is. in this digital age it's important to keep software levels up to date, with some exceptions. i'm including the web address for sony so you can update the ps3, but i don't think it's the problem. once you're are on their site you click on the ps3 picture & that link will take you to the software update pg. there you can review previous software updates. i quickly reviewed 1 of those & didn't see anything that addresses your problem.
http://www.us.playstation.com/Support/SystemUpdates
have you verified that the HDMI inputs are are enabled correctly? thereare 4 inputs. refer to pgs 25 & 26 of the owner's manual.
I would put the heat on your LG retailer. clearly the new main board is suspect. you had the functions prior to the swap. the board is probably defective, but with a different problem than what you had previously. i visited LG's site. they currently have nothing in their knowledge base that mentions the your problem, nor is there a software update.
if you need additional help. write back. good luck.
peace-out
Posted on Feb 11, 2009
opherator
  • 44 Answers
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Posted on Feb 27, 2009
I just bought a hdmi cable for my ps3, but when I
you need to connect to the HDMI input on your tv as well.. thats probably why its not working properly..
Feb 23, 2010 | Sony Playstation 3 (PS3) Console
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
PS3 is backwards compatible with PS2 games, and USED to play them
In Playstation Store, you should download (for free) the PS2 SYSTEM DATA (something like this).
if you have formated your system, the files were erased, and the games won't play until you download the backwards comparibility files again.
Jul 26, 2009 | Sony Playstation 3 (PS3) Console
Surround sound hok up
try using a HD plug in cable that should solve ur problem
Mar 01, 2009 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Resolution problems/ Game problems
Well it might be becuase your ps3 is european. Im no expert on the matter, but when i bought an hdmi cable and hooked it up to my hd compatible tv, i switched to the hd input (which happened to be input4 on my tv) and a message popped up saying that the ps3 has detected hd output, would you like to change settings? and it did it automatically after i hit yes.
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
No sound from hdmi cable
PS3 is The amazing device by sony but it has some common problems like sound but no video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
PS3 trouble shooting
i hooked up my ps3 with hdmi cord and it looks good, but the no sound so what might be the problem
Dec 27, 2007 | Sony Playstation 3 (PS3) Console
Samsung LCD tv and PS3
the problem is with the frames per second that the ps3 is putting out. i wound up calling both samsung and sony and the problem was in the settings. the ps3 allows you the option of playing in 24hz and for some reason if the option isn't turned off our tvs won't display frames at that rate. just go to the dvd settings and deselect the 24hz option, changing it from AUTO to OFF... the only problem i have with this is that this should effect the picture quality, becasue if it isn't displaying in 24hz that means it is downscaling the display and if it isn't upscaled by the tv's processor, then the display should be worse. i might be imagining it, but it does seem worse.. atleast they play now though. hope i helped.
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
