Question about Toaster Ovens
Beko 5512 oven heats at the top but not the bottom - do you know what part I would need to replace?
Bravetti toaster oven
Not enough voltage getting to the heating elements. Look at the thermostat or the control board for the problem
Jul 28, 2017 | Toaster Ovens
HEATING ELEMENTS
The heating elements are inside on the top and bottom
Jun 08, 2013 | Bella Cucina 13049 1500 Watts Toaster Oven...
Our Oster toaster-oven (Model 6232) takes a long time to heat up. The heating elements are no longer bright red but rather heat up to a "dull" red. Might the problem be related to the thermostat...
You might try going to oster.com. After putting in your country, at the top of the page click on Customer Service and fill in where you live and you will get a list of service centers that you could check with. If you know what needs replaced and can do it yourself, then use this address to get parts. This will give you a list of sites that sell parts. Maybe just get both parts to see which it is.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Mar 17, 2011 | Oster 6232 / 6233 1500 Watts Toaster Oven...
The bottom two heating elements have stopped working. Can these be replaced?
I do not know everything about every toaster oven out there, but I would guess that they can be replaced. Here is an address that will bring up a list of sites that sell parts. Maybe one of them can be of more help.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 10, 2011 | Oster 6058 Toaster Oven with Convection...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    WE HAVE A GE 169104 TOASTER OVEN
    Do you still need top elements or do you still have your GE 169104 oven?
    Apr 16, 2010 | GE 168947 Toaster Oven with Convection...
    Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
    it is several prosibilites for your problem:
    1) the wire of the oven is damaged;
    2) the thermostat is decalibrated or damaged;
    3) one or more heating element is intrerupted or burned.
    solution's:
    1) check the wire an replace or repair where is posible whit similar heat resistant wire;
    2) replace the thermostat whit similar one;
    3) replace the heating element
    Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
    Burnt pie
    YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
    Apr 13, 2009 | Toaster Ovens
    Top element not heating
    I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
    If you attempt this repair, UNPLUG THE OVEN FIRST!
    There is also a security screw at the bottom of the side cover.
    Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
    Toaster Ovens Logo
    169 people viewed this question
    Top Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Dave
    Dave
    Are you a Toaster Oven Expert? Answer questions, earn points and help others
