Question about Cycling
Both of the wheel discs are very tight because of the pads rubbing have tried putting two credit cards in and pushing knife inbetween but no success. do i release some fluid or any other advice would be most welcome.
    Sergeant:
    Champion:
  • 263 Answers
Loosen the nuts and use grease
Posted on Mar 13, 2011
HOW DO I SOLVE NOISY BRAKE PADS, ON 2008 VW BEATLE 2008. There is very little ware on brake pads.disk pads all round. Also is there any thing special, one needs to be aware of when pushing back pistons in...
No you sound like you know what your doing, there is nothing to be aware of when compressing the piston back in except make sure there is enough room in your reservoir for the extra fluid that will come back up (you may need to empty some out).
The problem with the noisy pads may be a little more tricky,
is it a squeeling noise you hear when brake?
is it a grinding noise (like metal on metal) when you brake?
or is it a constant noise?
if it is a squeeling noise the most likely senario is dust on the pads and disc's. this is normally a problem with cheap brake pads and may be solved by buying a more expensive brand.
if it is a grinding noise it may mean there is something else rubbing on the disc. once the wheel is off check for any rubbing marks from any part of the wheel or guards that are on the disc.
Aug 02, 2011 | 2008 Volkswagen New Beetle
I have XT Disc Brakes and just put new pads on front and rear, 1 set of Sintered and 1 set of Standard Blue. Once on and with Disc Pistons pushed back into caliper as far as they will go, the pads still...
Try taking out the pads and reseating them. I have found that sometimes the pads don't fully click into position and so they stick out a bit, which will cause minimal clearance and rubbing. Sounds like you have everything else in position correctly.
If this doesn't work, maybe you have a bad set of pads? happened to me recently on a set of Avid's.
Mar 28, 2011 | BBB DiscStop Mountain Bike Disc Brake Pads...
How can ichange the disc brakes on a renault 19
Hi there, I have a few steps here to help you out:
  • With your hand brake ON, loosen the wheel bolts to hand tight, jack up front wheel, chock back wheels, and put axle stands/blocks in place (just in case) .
  • Remove wheel. Disconnect pad wear wire, it pulls out of the connector.
  • Remove lower caliper bolt (at the back of caliper at the bottom), need a 13mm ring spanner for head of bolt and 17mm to stop it spinning
  • Use a screw driver between the back of the outer pad and the caliper to raise the caliper back away from the back of outer pad. Pivot caliper upwards to rest on top of wheel disc (good idea to tie it up with some wire) .
  • Remove and discard old pads , clean out with wire brush and soft brush , don't breath in to much of the dust its nasty.
  • Fit new pads (remember pad wear sensor on inside pad), make sure that the pads are in contact with the disc , and the top of them sitting flush with the rim of the disc, don't force them into this position they should naturally sit there.
  • Lower caliper down into position, you may need to push back the piston further in order to make room for the new pads , do this with you hands or a small piece of timber. Keep an eye on the brake fluid reservoir , your pushing fluid back in so if its over full it may spill over. Refit lower caliper bolt (Renault say to replace this each time), and tighten. Reconnect pad wear sensor.
  • Pump brake pedal until normal brake pressure returns.
  • Remove axle stand/blocks, refit wheel and bolts, lower jack and tighten up wheel bolts.
Hope this helps...
Jan 17, 2011 | 1986 Renault Sport
Disc rub on brake pads
First be sure the calipers are working properly. Test by pushing the brake hard and then spin the wheel. If this is new and it rubs - look closely and be sure it isn't the bend tab or warning tab rubbing. If they are old brakes replace as this is the warning you are needing to replace.
IF new - and they still rub - remove and inspect - be sure there is not a 'bend or warning tab' that is rubbing.
If there is no tab rubbing - you can SAND [ with sand paper] the BRAKE PAD carefully and squarely. I suggest you take these to a professional as the items I describe should be caught by a beginner.
Thanks for choosing
Gary @ Fix Ya
Jun 27, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Avid juicy sevens remain tight against disc
Juicy's are prone to sticky pistons.REMOVE pads,clean calliper ,pull lever lightly and add a drop of hydraulic fluid to the edges of the pistons to lube.Recess pistons,wipe off excess fluid and fit pads.If this doesn't work they might need bled.
Sep 25, 2009 | Avid Code Hydraulic Disc Brake
Change back Brake pads on renualt megane 2
1. Hand Brake ON , loosen wheel bolts to hand tight, jack up front wheel , chock back wheels , put axle stands/blocks in place (just in case) .
2. Remove wheel. Disconnect pad wear wire , it pulls out of the connector.
3. Remove lower caliper bolt (at the back of caliper at the bottom) , need a 13mm ring spanner for head of bolt and 17mm to stop it spinning
4. Use a screw driver between the back of the outer pad and the caliper to prise the caliper back away from the back of outer pad. Pivot caliper upwards to rest on top of wheel disc (good idea to tie it up with some wire) .
5. Remove and discard old pads , clean out with wire brush and soft brush , don't breath in to much of the dust its nasty.
6. Fit new pads (remember pad wear sensor on inside pad), make sure that the pads are in contact with the disc , and the top of them sitting flush with the rim of the disc, don't force them into this position they should naturally sit there.
7. Lower caliper down into position, you may need to push back the piston further in order to make room for the new pads , do this with you hands or a small piece of timber. Keep an eye on the brake fluid resivoir , your pushing fluid back in so if its over full it may spill over. Refit lower caliper bolt (Renault say to replace this each time), and tigthen. Reconect pad wear sensor.
8. Pump brake pedal until normal brake pressure returns.
9. Remove axle stand/blocks , refit wheel and bolts , lower jack and tighten up wheel bolts.
Sep 18, 2009 | 2006 Renault Le Car
HOW DO I CHANGE THE BRAKE PADS ON A FORD ESCORT I DO NOT KNOW HOW TO FIT THE BRAKE PADS
In very general terms...Take off the wheel then unbolt the brake caliper and pull it off the disc. Next remove the old pads from the caliper. Next you have to push the caliper piston right back into its housing. You can use a g clamp to push it back. If it is not right back the new pads will be too tight on the disc and you wont get it back on. Now put the new pads in the caliper and fit the assembly over the disc and bolt everything back together. When pushing the piston back check the fluid level in the resivior as the level will increase. If the fluid overflows it will damage your paintwork.
Aug 31, 2009 | 1998 Ford Escort
Brake pads are shut fairly tight. Can't get disc
Your brakes adjust automatically (so when the pads wear down your levers don't get looser). What you did was pull the brake lever and it adjusted making the pads shut.
Anyway all you need to do is take a wide flat-head screw driver and wiggle it back and forth between the 2 pads.
Jul 10, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Cycling Logo
22 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
