Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Hi printer wont move from paperjam even tho no paper in printer
    Problem Solver:
  • 10 Answers
Check there isn't a piece or scap of paper lodged deep inside. Pull out the power cord, and put your hand in the paper tray as far as it will go. If there is a piece of paper in there, slowly but firmly pull it out - making sure you don't rip the paper!
Good Luck! John.
Posted on Mar 13, 2011
Paperjam siplay no paper in the back
hi open your printer so that you can see the wheels that feed the paper into the printer and check that no paper is stuck in the meconisom is this is soum times wey it says paperjam
Apr 09, 2014 | Kodak ESP 3 Multifunction Printer/ Copier/...
Alarm is on keeps saying there is a paperjam--no paper in it wont function not even a year old
something will have fallen down where the paper goes at the rear of the machine. I had a receipt stuck in mine i could not see anything even when i opened the top cover, to resolve the problem i use a laminated A4 sheet of paper and pushed it through slowly, i was then able to see the receipt and picked it out with a knife, its been fine ever since
Oct 22, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper logjam
There is a line of sensors along the paper path, if any of these are obscured by even the smallest scrap of paper you will get the messasge, re check the paper path again it only needs a scrap of paper, if you can spot any of the sensors give them a blow with some compressed air (paper dust build up), last but worth a try unplug for 2 minutes to allow residual power to drain and then try power up and see if the message has cleared
Sep 11, 2009 | HP Officejet 6310 All-In-One InkJet...
The printer is still frozen due to a paperjam, even though all the jammed paper was removed.
Unplug the power cord, look at all the rollers for paper scraps, clean, check the little tabs that check for paper etc, make sure they are free to move and clear of paper scraps, make sure all covers are installed c.orrectly, plug back in and try
Aug 22, 2009 | Office Equipment & Supplies
Printer wont pull paper down then says paper jam
Dell does not make printers. They put their name on Lexmark printers.
I just repaired a 926 which had a paperjam alarm...and no paper jam. The paper sensor microswitch had been bent up onto a paper roller so the printer thought a piece of paper was stuck under it. It was hard to get the little lever off the roller and back, hanging free, without breaking it. This did not happen on its own so I can't fault the printer.
Look for this tiny black plastic lever hanging down right in the middle of the upper paper rollers, just behind where the carts run.
Jul 03, 2009 | Dell 926 All-In-One InkJet Printer
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
Stylus photo r220 not picking up 4by 6 inch photo paper
move the paper sideways (end on as apposed to flat) or select portrait printing instead of standard. good luck!
Mar 11, 2009 | Epson Stylus Photo R220 InkJet Printer
My NP6012 stops and paperjam light comes on. Paper not being fed.
Pick up wheels can be full of dust due the time storage.Keep on trying to make copies,the paper will clean the rollers every time it try to feed.
Jan 28, 2009 | Office Equipment & Supplies
PAPERJAM
hey gramma try to do one thing before even going for test page , open the panel and cover where u will be able to see the catridge ccarriers, try to blow air, or after opening the cover titlt the print and shake it gently sometimes due to some dust particle the paper jam happens
Feb 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
