Question about LG Cell Phones
Phone didn't update time for daylight savings.
  • 341 Answers
Try restarting your phone and see if it works.
Posted on Mar 13, 2011
2 Suggested Answers
SOURCE: LG600G did not update time for daylight savings time
I had the same problem. I simply powered it off, and powered it back on, and it had updated.
Posted on Mar 15, 2010
How do i update the time from daylight savings?
Double check the sntp setting on the others As see they are using the same server.
Mar 09, 2015 | Polycom SoundPoint IP 501 IP Phone
My Nokia E5 is set by default to daylight saving mode, but it is canceled this year in Egypt, so I need to uncheck the auto adjust daylight saving but I cannot.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select OFF, the phone will NOT
automatically update the date and time.
May 22, 2011 | Nokia E5 Cell Phone
Samsung Impression :Daylight savings time moved all the appts
This is the second Samsung phone I have had that did this. The A707-Sync had the same problem. I called Samsung tech support and they told me to disable the auto-update feature for daylight savings. Not a great solution, but the only one I got.
Nov 02, 2009 | Cell Phones
Palm Treo synchronize calendar daylight savings time
You need to go to your phone carrier support page, or to Palm.com and download the daylight savings time update.  You SHOULD keep network time checked unless you don't want to pull the proper time from your carrier, such as when you are out of town.
Mar 24, 2009 | Palm Treo 700w Smartphone
Daylight Savings Time
I am not sure if this is available for your version since I do not know who your carrier is. But you need to check on Palm.com and check under software updates and see if there is a patch. usually they have patches which you can uprade your phone with and hat will update yor time
Mar 10, 2009 | Palm Treo 750 Smartphone
Mar 10, 2009 | LG Shine KE970 Cellular Phone
Disable Calendar
The Settings menu provides you with various setting
options to customise the phone to your preferences
and needs. You can also reset the settings to their
default values.
To access this menu, press <Menu> in Idle mode and
select Settings.
Time and date (Menu 9.1)
Use this menu to set the current time and date on
your phone.
Home zone: set the home time zone. Select the
city that corresponds to your home zone. To set
daylight saving time, select Set daylight saving
time
Time: enter the current time.
AM/PM: select AM or PM in 12-hour time format.
Time format: select the time format.
Date: enter the current date.
Date format: select the date format.
Auto update: activate the auto time update
feature. Your phone will read the MCC (Mobile
Country Code) from the network and automatically
update the current time for the country that you
are in when you travel abroad.
Feb 20, 2008 | Samsung SGH-D900 Cellular Phone
Update time
try *2767*3855# after the phone reboots then adjust the daylight saving time. this process should correct the problem you are having.
Nov 04, 2007 | Samsung SCH-u340 Cellular Phone
My time doesnt change at daylight savings time
Go to settings,initial setup,time and date. change it to "off" on autoupdate.You'll get more options. You can change the date and time then.
Nov 04, 2007 | Motorola Mobility RAZR V3
Change the time
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Oct 29, 2007 | Panasonic KX-T7633 Corded Phone
Cell Phones Logo
24 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
