Question about APC Back-UPS XS900 (BX900) UPS System
Upc 900 why my overload alarme with no charge on it?
    New Friend:
  • 14 Answers
The overload circuit normally collects the current information from the inverter leg. At times when there is an actual overload, the protective circuit picked up the excess current as compared to the calculated value and thus gives an alarm. However at times when the inverter leg is short circuit or a leakage it also gives the same overload current. Is the inverter on when it gives the overload alarm? Please let us know.
Posted on Mar 30, 2011
Why does my 900w microwave trigger the LUP code & alarm?
you need at least a 1900 watt inverter with a fully charged battery to run a 900 watt microwave,it uses 900 watts to make microwaves and it uses 700 or so to run everything else.
Mar 11, 2015 | Inverter Electronics - Others
Kipor ig6000 overload alarm
most warning and alarm's are set less than what the manufacture rating is. it's a safety feature without it we would overload all our stuff
Sep 23, 2012 | Kipor Electrical Supplies
Help recognizing a type of UPC-A barcode
Hi, the easiest way to figure out the barcode type is to scan it with a reader...Then you could choose the barcode control or font to create the barcode yourself.
May 29, 2012 | Computers & Internet
I connected 8, 100Ah battery with APC 2.2KVA inverter, now it doesnt give correct battery indication and keep producing beeping noise, whats the problem?
Continuous Beeping (theamber On Battery LED will be illuminated)
This alarm indicates that the UPS has reached aLow Battery condition and will soon shutdown. The UPS can only operate onbattery for a limited amount of time. In order to protect the unit's batteriesfrom discharging too much, the UPS will shutdown and turn off its output. Towarn you that the unit will soon shutdown, the UPS will sound this alarm 2minutes before actual shutdown. With optional Powerchute Plus software, 2minutes can be changed to 5, 7, or 10 minutes to give you more of a warning ofimpending shutdown. If you hear this tone, you should immediately gracefullyshutdown your operating system to prevent data loss or corruption.
Note:This graceful shutdown will occur automatically if Powerchute PLUS software isbeing used.
Constant, Solid Tone (the red Overload LEDwill be illuminated)
This alarm indicates that the UPS has detectedan Overload condition. If this alarm is sounded, try removing non-essentialequipment. The alarm will remain until the load is reduced. To determine ifyour UPS is capable of handling the equipment you want to protect, visit APC'sSizing Guide at www.apcc.com/sizing.
Continuous Beeps for One Minute; RepeatedEvery 5 Hours (Replace Battery LED will be illuminated)
This alarm indicates that the UPS has failed itsSelf-Test of the battery. The unit will continue to sound this alarm until theunit passes the test. Try to let the unit charge for a few hours and thenperform another Self-Test (Press and hold the on/off button until the second'chirp', then release). If it fails and the unit is still in-warranty (twoyears from date of purchase), then contact APC. If the unit fails and its outof warranty, then order a replacement battey cartridge through your reseller,distributor, or from APC's web site.
Apr 21, 2011 | APC Computers & Internet
SO bad, and a bad response... I have 2 UPCs one started beeping for no reason, and will not stop...even when plugged into the wall with the battery disconnected... The other one is still silent. SO the...
These beep error codes may help you.
1. Four beeps every 30 seconds (On Battery LEDwill be illuminated)
This alarm indicates that the Battery Power Suppliedoutlets are now supplying battery power as opposed to power from the utility.If the UPS determines that the input utility power is unsafe for your computerequipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Battery condition hasbeen reached and that the UPS will soon shutdown. Once the UPS transfers to OnBattery operation, it can only stay on battery for a limited amount of time.The UPS will sound this alarm about two minutes before the batteries aretotally exhausted. Once exhausted, the UPS will shutdown and turn off itsoutput power to your equipment. If you hear this tone you should immediatelyshutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPSOFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overloadcondition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload was detectedwhile the unit was on-battery operation. This tone will continue to sound untilthe unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-powered outletsare overloaded.
6. Continuous Tone (On Line and On Battery LEDsflashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault hasoccurred.
Feb 28, 2011 | APC Back-UPS Pro 650 UPS System
Tone alarm goes off and flashes "overload" and on the back "building wireing fault" is lit up
The "Overload" light and alarm is to tell you that the devices connected to the UPS are drawing more current than the UPS can safely provide with battery backup. You should disconnect a few items, and the alarm and overload light will turn off. The "Building wiring fault" light on the back is to tell you that there's no proper ground wire inside the wall outlet that you're using. These two problems are not related to each other.
Mar 04, 2010 | APC Back-UPS® XS 900 (BX900R) UPS System
1995 Saab 900 alarm problem
You must LOCK Doors Manualy,then UNLOCK DRIVER DOOR WITH KEY this should Correct the Problem.
Jul 13, 2009 | 1994 Saab 900
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
APC Back-UPS XS900 (BX900) UPS System Logo
977 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
