Question about Zanussi 23 in. ZEL63 Electric Cooktop
Hi I recently broke the temperature selector switch for ring 1 on my Zanussi ZEL 63 6 kW cooker.The plastic switch broke off from the selector ring so the switch is now always on at 6 full Power Dors amyone know if is it possible to replace the selector switch or do i need to buy a new cooker ?I have been looking online but I can only find the selector plate covering as a spare and not the switch itself. Thanks Mike
    Genius:
  • 1,196 Answers
It is better you replace the complete selector switch on your zanussi cooker, this will be easier to get because just one might be very difficult, i will advice you check ebay.com or ereplacementparts.com for it.
Posted on Mar 13, 2011
Zanussi induction hob. Hot warning light remains on permanently for one ring. Tried power on/ off- no good.
Unfortunately this is not a user fixable issue,it is caused by a faulty temperature sensor,which needs replacement.
Nov 25, 2014 | Cooktops
Recently i have purchased Prestige induction stove, can you describe what does E3 mean?
e 3 is error because of high voltage may be more than 30 kW at your house......it will not work with it u have to buy a voltage regulator for it........
Jul 16, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
My Zanussi Induction cooker model ZKT 621LX is not working? When I try to switch it on, the display for all 4 cooking zones shows L and after a few seconds, it just shuts off? What could be the problem?
Hello Horus,
The child-lock has been activated - probably accidentally, but someone may think you're not safe to use it. The de-activate the child lock . . .
1. Switch the cooktop on so all zone show "L"
2. Press both the + sign for the right-front zone and the - sign simultaneously. All four zones will show "0" with flashing decimal points.
3. Press the - sign again. The cooktop will switch off.
You can now switch the cooktop on and use it normally again.
Hope this helps. If you have any difficulty de-activating the child-lock or need further assistance, please let me know.
Regards,
BElectric.
Apr 19, 2011 | Zanussi 23 in. ZKT641H Electric Cooktop
Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Apr 18, 2009 | GE 30 in. Profile JP350 Electric Cooktop
One of the elements does not regulate stays at high temperature
I would suspect the burner switch needs replacement.
Feb 01, 2009 | Cooktops
Left hand side not working
OK. I know whats wrong. On your terminal I guess you only connected the Large Brown wire to the number 2 terminal ( Live ) What you have to do is bridge terminal 1 and 2 together. You may need to peel back the heavy copper brown so you can split it evenly and ensure it can reach to terminal 1 and 2 . So what you have then is one cable feeding to both 1 and 2 terminal. If you have the smaller live brown wire just connect that to terminal 2 also. That should fix your problem. I will check back to see if you have any more problems..
Sep 16, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Zanussi 23 in. ZEL63 Electric Cooktop Logo
87 people viewed this question
Top Zanussi Cooktops Experts
fyigen
Brian Coughlan
Tom Chichester
Are you a Zanussi Cooktop Expert? Answer questions, earn points and help others
