Question about Kitchen Ranges
I have just received my new cooker hood with no installation instructions so i dont know max or min height from hot plate or distance cupboards need to be can someone let me know where to find the manual it is a Baumatic BTC6740SS 60cm Chimney Hood - Stainless Steel
  • 46 Answers
I think you can find what you are looking for on the following site:
http://www.devicemanuals.com/productmanual/Baumatic-support-Hood-manuals-page1.html
Posted on Mar 14, 2011
Ariston induction cooker
Check ventilation of the cooktop.
> Needs to get the hot air out towards the front of the cupboard and needs cool air from the back near the wall.
Best to get service agent to "finesse" the installation with a kitchenmaker.
Oct 16, 2013 | Heating & Cooling
Good morning We are about to fit a rangemaster classic hood 120cm approx. to suit our Elan 110 dual fuel cooker with a gas hob. What is the corrrect distance we should leave between the hob and...
In my experience, the hood should be just above head height, that will avoid banging your head, and at least 33 inches or 8ocm above the hob.
Hope this helps.
Nov 03, 2010 | Microwave Ovens
How far out does a microhood sit from the cabinet. My cabinets are 12 inches and the microhood I want is 16 deep. Also it will be 19 inches above my stove.
Don't know right off the top of my head, but the installation instructions should tell the min and max height from the stove. If they don't you may want to contact an electrician to find out.
Mar 29, 2010 | Kenmore 62622 Microwave Oven
I've bought a new cooker hood that filters the air and then re-circulates it. At what minimum height from the ceiling should it be fitted?
Its not the ceiling height that matters its the height above the cooker or hob thats important. Above a gas burner the bottom of the hood should be at least 750mm, above electric burner 650mm . This measurement should be taken from the highest point of the cooker top.
Nov 24, 2009 | Kitchen Ranges
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
Wiring problem
Yes just like damic says,
But dont forget to add a fused switch one as well.
You'll be glad you did.
What i did was..from the hood, i did a channel into the wall (with plastic conduit).. to go left then followed it down to make it flush.
(so i could put the cupboard back on)
Plastered then tiled up the area as well as added the extra plug.
It'll run sraight off the mains.
Apr 11, 2009 | Baumatic F60 Stainless Steel Kitchen Hood
How to use the reticle in my Fujinon Mariner Binoculars?
How to use the reticle:
The vertical scale (reticle) visible through the left half of the binocular, above the compass display, allows you to calculate distance to an object if you know its height, or to calculate the height of an object if you know its distance from you.
Each mark on the vertical scale has a value of 5 MIL (1Mil is equivalent to an angel that can determined an object one meter in height at a distance of 1000 meters). Therefore, if a navigation chart gives the height of an object, by sighting on it and counting the number of MILS, you can determine how far away it is.
To Measuer distance when height is known:
Object Height(m)/Scale Reading x 1000m=Distance in Meters
To Measure height when distance is known:
Distance(m)xScale Reading/1000=Object height in meters
Jan 26, 2009 | Fujinon Mariner WPC-XL Binocular
INDESIT HI161IX - positioning above the cooker
if its hidden hood that pops up it just has to be flush with counter
this is so you have a clean flat service that make it look like you have extra room
if its a regular hood like old days height should be between 2 to 5 feet from stove to hood for quality air flow easy to install
Jun 01, 2008 | Kitchen Ranges
Distance from lowest point
Normally the rangehood should be at least 700mm from the top of the cooktop.
Nov 03, 2007 | Miele DA 249-4 Kitchen Hood
Kitchen Ranges Logo
614 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
