Question about Intel Motherboard
Sound does not work - Intel Motherboard
  • 3 more comments
  • Ekse Mar 13, 2011
    50$ actually not 30.
  • Ekse Mar 13, 2011
    IGNORE THIS PROBLEM.
  • David Petry Mar 13, 2011
    Could you give me your operating system, Model#'s of system and motherbaord, if you have it and tell me if your using onboard sound or a sound/graphics card<
    Thanks,
    Dave
  • Ekse Mar 13, 2011
    Please ignore this problem.
  • John Hamelink Mar 13, 2011
    Hi there, can you run this program to find out what make your motherboard is:http://www.cpuid.com/softwares/cpu-z.htm... Go to mainboard, then type out all the information there.
    Thanks!
    John
  • Intel Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Posted on Mar 13, 2011
  • Ekse Mar 13, 2011
    i dont have a problem this was a misclick, ignore this page.
Why would tv sound work fine but while using roku 2 the sound suddenly stopped working?
If the picture is OK then check your sound cables, red and white if analog, or swap out the HDMI cable with one that you know works.
Also, on the SETTINGS screen make sure your audio is set to stereo not surround sound.
Dec 27, 2014 | Roku 2 XS
No sound on my A105 s4334 Drivers are ok and system thinks that sound card works.
Check with a external speaker if it works, else you might have to reconfigure the sound settings in control panel..create a new user profile and check as well if it works
Feb 28, 2012 | Toshiba Satellite A105-S4334 Notebook
The sound isn't working on my pc. I have checked speakers on a different pc and they work fine. Have you any idea what the problem could be?
Have you checked the sound driver? Does the sound work with headphones?
If the sound driver is correct and working there will be, when checking the sound mixer, moveable virtual slider controls.
If it works on headphones, the headphone socket may be faulty.
The likelyhood of no sound due to a power problem is not very high.
Nov 17, 2010 | E-Machines (T2824) PC Desktop
Sound card stopped working
1st you disable the onboard sound card in BIOS level, then install/update the sound driver for Maddog Prowler 4.1 DSP soud card will solve your problem.
Dec 08, 2009 | Mad Dog Multimedia Prowler 4.1 DSP Sound...
I have a Dell Dimension 4600, will a PCI Express sound card work in place of the original Sound Blaster 5.1 sound card
Well, the short answer to your question is "No, it won't work". The Dell Dimension 4600 does not have any PCI Express slots in it, therefore you can't install it, and therefore it won't work. But, if you installed a PCI sound card, it would work. The BIOS would recognize the add-on sound card, disable the onboard sound, and your sound will start going through the expansion card instead. Hope this helps.
Jul 18, 2009 | Dell (8H390) Sound Card
New Sound Card is not working.
Ted, the first thing you should do is go into your computer's BIOS and disable the built-in sound card. Once you do that, go back to your device manager and if the onboard sound card still appears there remove or disable it. Then reboot and your new sound card should be recognized and you can install drivers and begin using it.
Apr 25, 2009 | Computers & Internet
Toshiba satellite L10 117 sound problem
The internal sound does not work but external sound works.Please help. contact me ady_service_pc@yahoo.com
Apr 30, 2008 | Audio Players & Recorders
Sound
the sound card is to be attached to the isa slot, if working should receive its resource and work, carefully attach the sound card to the isa slot, if working sound card it will be read if not it won't then put a working sound card.
UZOWUANYA
e-mail uzowuanya@yahoo.ca
Feb 15, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
No Windows Sounds or windows sound functions but All media players work
Select control panel >Sound and audio devices >select Sounds> Sound scheme options check whether the windows default theme is set. if not then set windows default theme.
thank you !
Dec 24, 2007 | Creative Labs Audigy Gamer Sound Card
Intel Motherboard Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
