Question about Garden
Motor runns very, very rough and there is a smell of burning wiring insulations
  • 2,510 Answers
Your do not say what the tool/appliance is, but from your description it seems to have an electric motor and the symptoms you give seems to indicate an armature that has some inoperative windings. There should be considerable sparking coming off the brushes as well. If you continue running it, it will eventually just blow and stop altogether. The motor needs to be replaced, I have seldom had much success just replacing the armature.
Posted on Mar 13, 2011
Car dashboard lights wont turn on and smell of burning wires
If you're smelling insulation burning - STOP. Fuses should be blowing before insulation melts / burns.
Have the car checked my a trusted mechanic before using anything in the car that makes the wiring burn or melt.
Apr 16, 2014 | 2001 Ford Taurus
The motor does't turn on viking washing machine
Check for internal circuit breaker, fuses, or disconnected wires. Smell for burned electronics, bare wires (Insulation). Look for any gears or belts attached to the motor and check for anything that could bind up the movable parts from turning.
Mar 18, 2014 | Dishwashers
My Sunbeam mixmaster junior model-jc is smelling when it runs
the smell will be burning insulation on the windings of the motor probably from the brushes being too short and arcing on the armature thereby overheating the motor. suggest you take it to an appliance repair shop for quote on repairs.
Jun 17, 2013 | Sunbeam 2346 Heritage MixMaster Series...
Need to know if the cooling fan on a millermatic200 should be on constantly if not when should it come on
Oil the bushings on the cooling fan with a light oil, I use SAE 20W synthetic nondetergent oil- The fan should be running all the time. It provides the 24 volts for the control circuit and contactors.
What you smell burning is likely the insulation on the wire of the fan motor.
Jan 25, 2012 | Welding Tools
Heater in 2001 kia spectra stoped working
The burning smell is most likely an issue with the blower motor. These small motors have a hard life and the windings can lose the insulation and short out, hence the burning smell. Another problem can arise if the air intake has filled with leaves and other matter which can be ignited by the fan speed resistor creating the smoke. As this matter rots down, it creates chemicals which can erode the insulation on the motor and cause burning and the eventual failure of the motor. The fan speed resistor is a bank of wirewound or solid state resistors wired across the fan motor which give the individual fan speeds. If these fail then you would lose the fan as well. Search out the fan housing as the resistor is usually fitted into this housing to keep it cool. NEVER turn the fan on if this resistor is out of the housing as it WILL get hot and It can cause a nasty burn..the resistor can have upto 7 wires plugged into it but as to it's exact location, that you will have to find on your own..
Dec 29, 2009 | 2002 Kia Spectra
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
My filterqueen majestic is 10yrs old and just started to spark and smell of burning ive took it apart
If you have a burning smell from the motor, your motor is shot. You should be able to buy anew AMTEK Lamb motor for about $85-110 US. Request a double ball bearing motor as it will have a longer life span.
Also buy a fresh internal filter kit. There will be a small 5 .5 inch filter disc inside the cone protecting the motor in the event that the cone tears. Replace it .Also save and reinstall the small insulating disc that sits between the top of your motor and the screen at the top of the vac. This is to prevent electric shock. This disc is the size of a coin.
Post back if you need more help. Wiring is very easy. Do NOT twist your wires before installing into the connectors, twist the connectors, then tape to be certain they are on tight.
Nov 04, 2009 | Filter Queen Majestic Canister Vacuum
Last night my wife accidently turned on the microwave with nothing inside. It probably ran for 15-20 minutes before I noticed a burning smell (burnt wiring) After opening the door I noticed the unit had no...
well I can tell you roughly what happened. You overheated the oven, as there was nothing inside to absorb the radiation. So the sensor shout off the power ( safety switch) It returns when the oven reduces in temperature. The burning may be due to internal damage to some of the insulation compound. It takes foreverf to get rid of smells from microwaves no matter what you use including vanill or some other anti stink medicine. The unit is probably OK but overtime will now begin to deteriorate and may even leak radiation to greater extent.
Dump it is my suggestion, but make sure it is damaged sufficiently to prevent dump rats from salvaging it and using it.
The unusual noise ( almost missed that) is damage to the rotation motor bearins that have been expanded and are now out of alignment.
Too risky!
Jul 31, 2009 | Microwave Ovens
Amana bottom freezer has a burning smell coming from the back of it. Fan is still working.
Is this burning smell occurring during a defrost? Something, like a food particle or wrappping, could be burning while in contact with the defrost heater. Is the burning smell coming from within the freezer? If it is coming from the outside and back of the box, unplug the box and investigate, or call a technician. You may want to call a technician, anyway? We don't need house fires.
Jul 07, 2009 | Amana ASD2326HE Side by Side Refrigerator
BURN SMELL NO PICTURE
Burned smell indicates some board level component has shorted and /or burned. Also, there could be high voltage arcing which has burned through the wire insulation. Safety circuit has shut down the unit to prevent further damage or fire hazard
Jul 30, 2008 | Televison & Video
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
