Question about Brinkmann 5 Burner with Smoker 8101750S
Grill is not getting to maximum heating potential. I have changed the exchanged the propane tanks and my flame is STILL VERY LOW LOW, even when the control knobs are turned up to "High"
    Brigadier General:
  • 4,736 Answers
Here's the problem and solution. The LP tank has what's called an OPD Valve. It prevents overfilling. However, if you turn the tank valve ON as you would normally do, it shoots high pressure to the grill's regulator and locks it up.
Solution: Turn the tank valve OFF. Disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Now, turn the tank valve on VERY, VERY SLOWLY (slow motion, slow), until the valve is fully open. Turn ON and light the burner farthest from the tank first and turn it to the highest setting. Repeat that procedure with the remaining burners. Have the flames returned to a normal height? If so, you solved the problem. If not, repeat the procedure again, but this time leave the hose disconnected for 10 minutes. If both attempts fail, you will need to replace the grills hose and regulator, as the regular is locked an won't release itself. You can find the hose/regulator assembly at any home improvement store or hardware store.
Just remember to always turn the tank valve on VERY, VERY, SLOWLY,
Happy Grilling!!
Posted on Mar 13, 2011
I just bought a brand new kenmore elite grill (for $199). I am new to grilling. The burners seem low - the one on the far left in the back has a flame but all other flame levels are low. Also, I cannot...
If the burners are set to the high setting and the flames are still very low, you may have a bad propane tank. The valves on the tanks go bad sometimes. Take the tank back to where you bought it and tell them you think the valve is bad. They should exchange it for free assuming it still feels full. This has happened to me before, i thought there was something wrong with the grill and it was just a bad tank.
Jun 06, 2011 | Kenmore Grilling
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
Feb 27, 2011 | Brinkmann Charmglow Stainless Steel LP...
Flame not staying lit
This is a common problem with grills purchased after 2001. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Tanks2youpropane@gmail.com
Mar 28, 2010 | Thermos Grill2Go Gas Grill 4656110
When I light my grill only one side of the burner has a flame, on all 3 burners. I cleaned everything and even cleaned each hole in the burners. What's next?
Ben Gaetani
Tanks 2 You Propane
Mar 02, 2010 | Grilling
Is not heating properly , the flame is not as strong as it used to be.
Ben Gaetani
Tanks 2 You Propane
Jan 18, 2010 | DCS BGB36BQARN (NG) Stainless All-in-One...
Low flame
The newer type tank has an anti tip safety device. It gets all boo boo'd when the grill is moved around. Remove the tank. Open the valves on the grill and close them back. Re install the tank and slowly open the valve.
Jun 27, 2009 | Brinkmann ProSeries 810-6330-W Grill
My Jenn air BBQ grill will not heat up all of
Couple things could be happening here. If you do exchanges, have you used more than one different propane tank since you've had this issue? This eliminates the possibility of a low tank pressure and a faulty tank connection. Next you need to look over the burners and the propane flow tubing. Spiders LOVE the sweet smell of propane and make their webbing inside the piping that get's the propane up to the burners. At your flow valves/On/Off knobs you'll notice that the propane shoots from the valves into a pipe with an air gap to gain oxygen. Look in there to see if there's any webs. Also should be a gap were that piping meets the burners, so you need to look there too. Depending on the age of the grill, you need to look the burners over. Corrosion & rust can cause the flame/propane holes in the burners themselves to cake up and close up causing much less flaming/heating opportunity. Also depending how much you've used it, it could be grease/dripping/sauce caked up over them too so they may need to be detailed/cleaned. It's not a pretty job, but grill maintenance that should be done every spring. When the burners get caked is when it's really fun and you need to remove them and clean out the holes with toothpicks. Jenn Air makes quality products, but being a BBQ and outdoors, it's just as vulnerable as any other to elemental and use issues. One last thing to check, some regulators (the disk shaped part right where the hose attaches to the tank) have another air mixture intake there with a screen on one side. Make sure there's no water in it and the opening is face down if you have one like that. Otherwise it's restricting the flow of the propane. I haven't seen one of these in a while, but they're still out there so check it too.
Jun 10, 2009 | Thane Q-BBQ Grill
LOW HEAT WHEN ON HIGH
This can be caused by the safety valve in the propane tank. Most times this can be corrected by tuning off the valve on the tank, make sure all the controls on the grill are in the off position. Then turn on the tank valve and try restarting the grill. All the controls on the grill must be off, before reopening the tank valve. If that does not work try another propane tank.
Mar 14, 2009 | Weber Genesis Silver B Grill
Flame not hot
If the propane tank is full, it could be the pressure regulator. Some regulators have an adjustment screw on the top.
If it's REALLY cold outside, the propane may not be evaporating fast enough to keep the pressure up. Also on a cold or windy day, heat is drawn away from the grill very quickly, and it may be difficult to keep the temperature up inside.
(And Happy Grilling!)
Mar 31, 2008 | Vermont Casting The Extreme VCS5005BI...
Brinkmann 5 Burner with Smoker 8101750S Logo
311 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
