Question about Video Game Consoles & Games
Do you leave the the wii remotes on the chargers at all time or do you take them off once they are fully charge
    President:
  • 1,139 Answers
Hi there, the Wii remote charger stand has a smart charging system which means that once the batteries reach full charge capacity the charger will stop charging them. You will cause no harm by leaving the Wii remotes on the charger all the time.
Hope this helps
Posted on Mar 13, 2011
I bought a Ryobi 12V drill w/ lithium charger. Green light on charger never went solid....continues to blink & fade. Does this mean its in the energy saving mode? Is it fully charged?
How long have you left battery on charger? It will take about 3 1/2 hrs to fully charge. t is probably not a good idea to leave the battery in the charger for long periods of time though, so once it is fully charged put it back in the drill. When fully charged the green led will turn solid. This link will have more info on charger and battery.
http://powertool.manualsonline.com/manuals/mfg/ryobi/130155001.html?p=2 C
Apr 19, 2017 | Ryobi Drills
How do you charge your wii console
The Nintendo Wii is an innovative video game system and much like other video game systems within the Wii's generation, the controllers are all wireless. Because of the wireless technology, the controls must function on batteries in order to operate. Instead of having the game pause in the middle of the action, there are plenty of methods you can test to make sure your Wii remotes are fully charged.
instructions:
  • Charge you're the batteries to your Wii remote by opening the back clip and pulling out both AA batteries. If the batteries are the standard set that came with the Wii, you should upgrade them to rechargeable batteries to save time, money, and garbage waste.
  • 2
    Let the batteries charge for as long as the charger says. In most cases a full charge could take 6 to 12 hours, but fast chargers can fully charge batteries for an hour. Check the charger's manual detailed times.
  • 3
    Use a Wii Charging station for easier charging access. These stations avoid the process of opening and closing the Wii remote every time you need to charge the batteries and they work as a Wii remote stand as well.
  • 4
    Place the batteries back into the Wii remote once the charging has completed. With both the charging stations and rechargeable batteries, lights should indicate when the charging has completed.
  • 5
    Power up the Wii and press any button on the Wii Remote in order to turn it on and connect with the Wii.
  • 6
    Press the "Home" button the Wii Remote control. This button is in the center of the controller and features a small picture of a house on it. A pop-up menu will appear over the screen.
  • 7
    Look at the menu and find your controller number. Right next to the assigned number is a remote battery meter. It will feature 1 through 3 bars to indicate battery level. If it has 3 bars, then the Wii remote is fully charged and ready for use. If it has any less bars then the remote can be used, but is not fully charged. If the battery meter is in red, the remote will shut off soon because there is not enough battery power.
  • Dec 06, 2011 | Nintendo Wii Console
    CAN YOU LEAVE A RECHARGEABLE BATTERY FOR A 19.2 VOLT CRAFTSMAN CORDLESS DRILL IN THE CHARGER ALL THE TIME/
    It depends on the charger taht comes with this drill, the dumb charger will just keep on charging the batteries even when it if fully charge and does not sop, which will be bad for the batteries, the smart charger (more expensive and has electronics inside the charger) will go into floating charge when the batteries are fully charge which will prevent the batteries from being overcharged. If in doubt, remove it from the charger after overnight charging.
    Nov 23, 2011 | Drills
    Hello, When i try and use the Wii remotes [after charging in the Wii charger dock] all the blue lights at the bottom of the controller flash and then nothing...........also when the controllers are in...
    The flashing lights likely means the controllers are not synced to the Wii. Syncing them to the Wii is really easy, luckily
    Generally, you can find the sync button under the battery cover on accessories, which should be a small red button. Look around your remote for it.
    After you find your sync button on your remote, find the one on the Wii. It is above the SD slot, and you will have to pull open the cover to see it, which is the little rectangular cover on the front of the Wii right underneath the power and reset buttons. The sync button is the little red one.
    Once you've found both buttons, hold them both down at the same time for about 3 seconds, then let go and the two should sync with each other. You only need to do this once and you should be fine.
    Apr 20, 2011 | Video Game Consoles & Games
    What to i need to do when the wii charger is green
    If your controller is still sat in the charger then that is fine when the green light is on. The chargers have what is called smart charge technology. This means that when the controllers reach full battery capacity the charger stops sending charge to the controller until it drops below a certain charge level again. Leaving the remotes in the charger when the green light is on will not damage them in any way at all.
    Hope this helps
    Dec 19, 2010 | Nyko Charge Station for Nintendo Wii
    After charging the wii remotes in the base until
    I don't think you are doing anything wrong, just the setup you are useing is'nt as effective as you would like.
    I use the energizer rechargeable (NiMH) batteries with the energizer 15 minute charger. The other batteries and chargers just don't seem to work as well. I get several hours of play time on a single charge, where I was only getting about 1/2 hour to an hour with the others. **No I am not a paid endorser, I just use and like the product!**
    Hope this helps, please let me know how you end up or if I can help more.
    Mar 05, 2010 | Nintendo Wii Console
    I lost the instructions to my wii battery charger. Would like some instructions knowing when battery is fully charged, can you leave the controller in the charger when only using one at a time ?? please...
    There's probably some light on the charger that would either change color or go off when the battery's charged. And it's usually okay to leave the Wiimotes on the charger when not using them, but I wouldn't leave it on there for super long amounts of time if you're not going to be using it foe a while.
    Nov 22, 2009 | Nintendo Wii Console
    My phones (philips cd445) will not hold a charge for more than a few hours off the cradle...yes I have replaced the batteries, twice. once with disposables, once with rechargeables
    You might have what is called "memory'. If you continue to replace the phone on it's charger after each call the battery will "think" it's empty, giving you s short charge time. Next time you replace the batteries (rechargeable) FULLY charge them then leave the phone off the charger until you go to bed at night.
    Sep 18, 2009 | Philips CD4452S/05 Digital Telephone and...
    Video Game Consoles & Games Logo
    420 people viewed this question
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
