Question about Panasonic KX-T7730 Corded Phone
Hi i want connect a 7730 phone call to fxs port dvg 5008 .. what settings should i do?
  • Panasonic Master
  • 2,460 Answers
A 7730 is a Panasonic system phone. It requires a Pana system to operate, so I'm confused as to what you're asking. If the phone call is INTO a 7730 phone and you want it to a phone on the DVG, you will need something to transport it, like an FXO circuit tied to the Panasonic's station ports. If the phone call is FROM the DVG and you want to answer it on a 7730, you plug the FXS ports into the CO ports of the Pana Key Service Unit that the 7730 is plugged into.
Hope it helps.
Carl
Posted on Mar 13, 2011
Audio distortion bogen tpu100b
This is am Impedance imbalance. Most inputs are looking for 600ohm. You need to use a different input or get a way to change you FXS to something else. What we usually do is buy the cheapest IP phone you can and wire directly to speaker. then simply call phone and it will page
Dec 17, 2013 | Bogen TPU100B TPU100B
I have a 1 port fxs voip voice modem, i have connected it and it is working. but the problem is that any time i power off my pc, i will have to reprogram it. can any body help me please?
the pc and ata are not reliant on each other. ensure the ata is plugged directly into you router.
unplug the lan lead and do a factory reset the ata via the ivr. once the unit has restarted plug in the lan and get the ip address via the ivr. set up the ata, rebooting after each page update (do not update more than 1 page before rebooting the ata).
you should now have a functioning ata and should be able to turn off your pc without issue.
if the ata now loses its settings then it is probably faulty (I've had a couple of ht386s go faulty in a similar way).
Apr 03, 2011 | Gateway 1-Port FXS/FXO VOIP (MTSMVP130)
Hi , i have one T-7730 . is there any way that i can connect it directly my phone line ? what kind of setting needed ? cheers
No. None. However, you can search E-Pay and find a compatible KX-T series system for less than $100.
Carl
Mar 31, 2011 | Panasonic KX-T7730 Corded Phone
I have use llinksys PAP2T togather with Panasonic KX-T7730c. does it possible?
Gather what? A PAP2T is a 2-port FXS box. A 7730 is a phone that works on a Panasonic Key Service Unit. You can plug the CO lines of a KSU into the PAP box and the 7730 into the KSU and get dial tone on whatever line you used on the PAP if that's what you're asking.
Carl
Mar 24, 2011 | Panasonic KX-T7730 Corded Phone
I have a D-Link DVG-G1402S router, I'm trying to setup VPN connect for a windows VPN server, which inside the network. I tried use modem directly connect to the server, it work, so it process my...
The router's PPTP passthrough and IPSec settings assume that you're connecting to an external VPN server on the public side of the network, but it sounds like you're hosting your VPN server inside your local network. If this is the case, you may just want to have your windows VPN box in a DMZ, or get a router that you can exert more control over. Be wary, if you're doing this at a residential location, your internet provider will probably block or "shape" this type of incoming traffic to your local network.
Mar 05, 2011 | D-Link DVG-G1402S Wireless Router...
Hi I have a panasonic KX-T7730 and I need to connect it to my linksys PAP2T Device. but I haven't Voice Over It. can I use this device with KX-T7730?
The 7730 is a Panasonic Analog System phone. It plugs into a Key Service Unit and the line port plugs into the PAP2T device. Model numbers like KXT-A624/824 are examples.
Carl
Feb 18, 2011 | Panasonic KX-T7730 Corded Phone
Using a kx-t7730 on the kx-td308 system. The phone will only work correctly when connected to the primary extension (11). for all other extension I get a display on the phone but no dial tone.. Can anyone...
A 7730 is a proprietary ANALOG phone. It requires 4 wires to make it work. In the U.S. version of the TD-308, the first 4 ports, by default, will accept an analog phone, the 2nd 4 ports require an expansion card. The Amphenol cable from the system uses the first 2 of every 3 pairs per station, so, pairs 1&2, 4&5, 7&8, and 10&11 make up the first 4 analog ports.
My guess is the installer cheated and only ran 1 pair to the jack, specifically the DATA pair, that's why the digital phones work and only the displays work in an analog set. Run the 2nd crossconnect on the 1st pair and the phone will work.
Carl
Sep 26, 2010 | Panasonic KX-T7730 Corded Phone
Lan driver problem
A D-Link Router is a "plug-and-use" device.
Just connect its 'WAN' port to your cable-modem (or DSL-modem) and connect one 'LAN' port to the network-port on your computer, and you'll be connected -- there is no need for a "LAN-driver" for the DVG-2001S Router.
Apr 16, 2010 | D-Link (DVG-2001S) Router (DVG2001S)
Panasonic KX-T7730 Corded Phone Logo
110 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
